AGM wont fully charge on a standard charger, termination voltage is higher. It doesn't matter, your Jeep doesn't fully charge the battery either. AGM is great because flooded cells get damaged if you hit them hard off-road. Most people don't ride on their skids these days so if you don't you will probably do fine with a flooded battery. Bouncing around on your tires and suspension isn't really an issue it's the hard hits on your skids that make you check your fillings that bust plates on a flooded lead acid battery.
