Homemade Bump Stop Idea?
Bump stops are meant to be a hard limit to up travel. They really should be a rigid material. If you want a cushion to slow down that impact, then that is what the jounces are for.
For me, just to be safe I need just 1/8th or 1/4th more bump for my fronts.
At work we have these paddles to dehair hogs, after they break we replace and I’ve used them for a few things on the Jeep
Reactions: JMT
Good stuff. My dad used to bring home pieces of old mining conveyor belts for random things like that.
Reactions: JMT and Thunderhead
@JMT the irony, I was looking for hockey pucks on Tuesday. I gave up and ordered a dozen of them on Amazon.
Reactions: JMT
You have never been hit by a hockey puck. They are very tough.
Me getting hit with a slap shot is not the same as a 4500lb vehicle crashing an open ended 2" pipe into a hockey puck. One will leave a nasty bruise, whereas the other has the potential to be a high speed, high force cookie cutter.
Hockey pucks work well enough as bump stop extension until they don't. There are better options.
I thought he had stock bump stops and needed to limit travel?
I have not heard of hockey pucks failing. I had pucks from my hockey days. I had to buy bolts and a forstner bit. I'll use them 'til they don't.
The project is putting some 2” springs and Rancho shocks on @KCsTJ tomorrow. He’ll be running 31’s for now
Reactions: KCsTJ
I’ve seen pic where some one used hockey pucks for a body lift and they split. The jounce bumpers above them in the front is way softer.
Right. I’d think it would have to be an awfully hard hit. I dont know. I hope I never find out. LOL
It doesn't take much. Speed bumps, unexpected dips. I suspect you've been there more than you realize.
Stock is about 4" of up. Mine has 6" front and 7" rear. I'll easily use 5+" going to the grocery store. ;)
