B
Bhodi
Guest
So, I've been restoring a 2002 Jeep TJ SE. So far I've replaced every front suspension component aside from the axle itself (I was experiencing death wobble, and then minor speed wobble, for about a year and only after the final component swap am I finally able to drive it above 60 mph.
The TJ has a ~ 2 inch suspension lift (Spring length at ride height is 14 inches front and roughly 11 inches rear). I dropped it from a 4 inch suspension lift with 33 inch tires to 2 inch with 31s (quite frankly, the engine just couldn't handle the size and the lift was installed by the previous owner without factoring in anything like castor, etc).
I noticed after replacing the rear shocks yesterday that the rear track bar, control arms, and sway bar look about as warn as you'd expect for components that probably haven't been replaced for the life of the jeep. So, I'm wondering, how worth it is it to replace those components?
If it will make a big difference in performance/ride quality I'm inclined to do it. I've used currie track bar, currectlync, and savvy control arms up front. Love currie/savvy and would want to do the same in the rear but don't know how to weld so would love recommendations for rear track bars from another brand.
Thanks so much for your help. I've been lurking here since I bought the jeep and these forums have helped me tremendously in restoring it. Side note, this is my daily driver but used for light off-roading on occasion.
