Good point on the water pump. I am thinking maybe I should replace mine as well, I am already tgere
Just ordered Mopar water pump.
I am at 150k miles and am assuming that everything is original. Especially the way the radiator blew up.Good point on the water pump. I am thinking maybe I should replace mine as well, I am already tgere
Followed guidance on the forum and spent the bucks for Mopar. I have to say it was very tempting to go with something less expensive since there were so many options that were still rated fairly well and priced anywhere from 1/2 to 1/4 the price. I resisted and bit the bullet...
[URL]https://www.amazon.com/gp/product/B009DKISHK/?tag=wranglerorg-20[/URL]
Mine used to run slightly hotter than 210 before I did a chemical flush and cleaned out the entire system. I ran it a total of 8 hours. Thermocure or Blue Devil is what I use.
I ran so far 3 flushed with BlueDevil, it didn’t seem to matter too much, as the color of the distilled water that I used in flush didn’t really change. I poured in Thermocure, and it it started to get black really fast. Are we expected to flush with thermocure till the coolant stays the same, and does not turn into dark black stinky thing?
This is the water after Thermocure. Left after first, and so on. Far right is probably good to go, but I drained one more and didn’t take a pic, was slightly clearer.
I just ran thermocouple for like 20 minutes, to burp the air.
And this is what I get:
I will run every lap for couple of days, with at least 3 hours of driving in total.I ran thermocouple for 1 1/2 days. Not saying I did it right, but this stuff reacts to rust. I’ve cleaned a lot of parts and BBQ smoker parts with Vinegar, and a few others that are more expensive, it takes 12 hours to a couple days to get a serious cleaning. I thought the bottle said 3 hours up to 3 days, but I don’t recall exactly. It obviously got some, but it was obvious to me that the stuff worked on it after a few days. Stunk to high heaven as well.
Plan to drain the entire at the end of the process. Now when I did it one time, I can do it again.
The only problem with draining the block is the sudden shower that one gets when the plug finally comes out.
You found a drain plug on the block ??? I didn’t think we had those …
I think that I have found the root cause for my overheat problems.
I bought this kit for 90$, OIMERRY 28PCS Universal Radiator Pressure Tester for Vehicles, Vacuum Type Coolant System Pressure Leak Tester Kit https://www.amazon.com/dp/B08BXZNNYF/?tag=wranglerorg-20
And ran positive pressure test. At around 13 PSI, I see that the coolant started to leak from the heater core.
I am currently running distilled water with thermocure, so my cabin stinks of thermocure, with this thing mainly pouring under the Jeep from the tube that is supposed to be for condensed water from AC.
With leaking heater core, it is not able to build proper pressure of coolant, and this brings air into the system.
I wish I had run this test before I replaced the fan clutch, before replacing a thermostat and before ordering a new Mopar radiator.
My lessons learned - always run exhaust in coolant (which I didn’t run yet) and positive pressure test. If any of these fails, no point in replacing half of the cooling system.
I replaced mine a few years back. Wasn’t to difficult, just time consuming.
https://wranglertjforum.com/threads/another-heater-core-replacement-and-a-c-evap-core.15568/
There are some other write ups for it on this site as well.
Short term, I did this. Dorman bypass, I had the same issue, but I went ahead and replaced everything and did this, heater core is on the bench waiting for it not to be 105+ in my garage.
Dorman 626-001 Engine Heater Core Bypass Kit https://www.amazon.com/dp/B09JHW9VSG/?tag=wranglerorg-20
