MiRustyjeep
The MC TB might be too long for that low of a lift. Might want to check that if you go that route.
That's true. I was just thinking, if he's already shifted 3/4", he'll probably shift more after the lift. But the JKS may be better if it fits lower lift heights. So good point. It's tough at low lifts to find an adjustable trackbar. Probably why some just drilled another hole on the axle side, not that I would suggest that course. I've only seen that solution, never investigated whether it is a good one.
I've had my JKS front TB on for about 8 years with no issues. With my low lift, the TB still has a lot of thread to adjust shorter if needed. Once you got that route you're kind of stuck with that style of TB since you'll be drilling out the taper on frame side mount. Just FYI.
Looks like @Ranger_b0b 's original plan is spot on, but yeah, your stuck once you drill out the taper...
View attachment 23840 Recreate this and make millions lol
Recreate the Rock crawler rear bumper
Sent from my SM-N920V using Tapatalk
Reactions: Kathy
Dropped some coin today...
Morris 4x4 had a end of year sale, 10% off entire order (eoysale), so I jumped on it. Going to pick up the Savvy cable shifter too. I'll have a couple of DIY projects to do, like turn some bump stop extensions and possibly make some end links for the rear sway bar. I'm also not going to put the adjustable rear track bar in yet. We'll see how the bracket does. At only 2 inches of SL, I think I'll be ok.
Reactions: Kathy and Starrs
Very nice setup. I have the JKS body lift also and the OME springs
Reactions: Mike_H
Solid purchase! You'll be fine with the rear TB bracket. It's a PITA to install. What shocks did you go with?
Reactions: Mike_H
Tracking numbers are coming in...I have a JKS shipment coming today and my Savvy Cable is on its way!
With respect to the Savvy cable...
How much will I need to lower the transmission to remove the upper nut on the TCase so I can install that bracket? it gets to be a small space up there! And, how much can I lower it without damaging something? It’s the only part of the install that’s bugging me.
I don't have ANY idea! :) It shouldn't take too much though. You can lower it a few inches for sure. The other piece of advice I've read is that taking the front driveshaft off makes a big difference. I've got a 241OR T-case too, which is noticably bigger than the 231.
Reactions: JMT
When I installed the Savvy cable on a 2003 X, I did not lower the TC skid at all. I don't remember it being a big deal with the install. I would think taking the drive shaft off at the TC would be more useful IMO.
Reactions: Mike_H
My transmission was only lowered by about a half an inch if I recall. I removed the transfer case skid plate, but not the front drive shaft. I think I have a thread around here somewhere with my install notes. I'll try to dig it up.
Edit - didn't find anything.
Pulling the skid should give you plenty of access to the linkage.
The instructions say pull the crossmember to get better access. I'll of course, drop the skid. I'll take a look when I get under there. Need to get this installed, as the stock linkage is all jacked up now!
Another byproduct of the evil BL. Hehehe!
Not a necessary evil. A good excuse for a wonderful upgrade. Your logic is all off, Man!
Perhaps. Guess it's inevitable if you want to lose some belly fat. I'm fighting it kicking and screaming until I have to cave in and do it.
Parts are coming in! I've got almost everything now. Still waiting on my transmission mount and my cable shifter. Not sure why, but Savvy requested my shipment be returned to them before being delivered to me. No biggie...but I also didn't get any explanation.
Anyway...
The JKS body mount kit works just like the savvy, in that it mounts over top of the factory mounts. It is not aluminum though, its a polyurethane type of material. Feels nice and hard though. Hope I don't regret going JKS vs Savvy.
3dgIfgdHoFKu0aW0hV5HskG0D7kNoTU3fLQljI2Ei-MPd3mQotzJO7FGxV1g1CuBdeIZVIzWyN06MeFXmI6=w359-h637...webp
The M.O.R.E. motor mounts also came in, and Damn...These things are STOUT. Very happy with this purchase.
f1ej3_ZPSaaBnksxy3Ic_neJgbW6UgPpLzcRhYS7hL1-QI3N3V3DNcs61T7mBv_ECVP67B6eUnFmrzavBIn=w359-h637...webp
Overall, I've been impressed with the parts feel. The JKS stuff feels quality, the M.O.R.E. stuff feels quality, the OME stuff feels quality. My wife was asking me why I spent 900 bucks, and only got 3 inches or so of lift. I told her 900 bucks was a STEAL for 3 inches of lift. When I'm done...it should ride better than it does now. Last time the two of us went offroad...she was complaining that she should have worn her sports bra!
Reactions: derekmac and JMT
