Lucky. Don't forget to post up some pictures. My father in law who lives in Riverside is towing his toy-hauler up there and staying for a few days as well.
Will do. Hopefully will get some video too.
Are we talking about feb or march?@Alex01 , Daylight Savings is the 10th, so I think anytime after that so we have more daylight. Maybe the 23rd weekend?
Your quick. You beat my edit.Daylight Savings is March 10th, so yes March.
I'll talk to the boss later tonight and see if I can get away with it. I'm still hoping to find time to run up to your neck of the woods and have you weld on those extensions. Maybe after its done we can throw yours on the rack and tackle some of the parts you have laying around.We could also do another snow run if you want to do something sooner.
The weld certainly doesn't look clean. But I bet if they would have ground the edges a bit it would have looked much better.While that looks very functional, it looks like crap, lol! Not sure what they used for the filler piece. I also wonder, did they have to remove the fender to cut that in half?
I'm in. Ill head up early the 23rd and wheel all day.
@tomtaylz you have a deadline now for testing.
I think that's his goal, to have it done by Holister for a test run before Moab.Think you'll have your trailer ready by then @Alex01 ?
Yes it did. Put the catilytic converter back on too since it was up on the rack. Got tired of the check engine light coming on all the time and having to clear it. Use the Samurai on the ranch for hunting now. Greased all the zerk fittings, checked all fluids.Everything go ok with your axle swap?
As lowranger said getting it done before Hollister is the goal. I would really like to have the jeep on it before taking it to Moab. I don't think it will be to bad of a job just time consuming. To bad your not closer since I'll need to get about 2 inches per side of weld burned in to hold it back together. I'm assuming I can run it down to the local exhaust shop and have them do it.Think you'll have your trailer ready by then @Alex01 ?
Nice. Did you mount the factory pumps yet? Front also or just rear?Was looking good inside.View attachment 75915
Factory pumps?Nice. Did you mount the factory pumps yet? Front also or just rear?
