So I already have an NV3550 transmission and transfer case I plan to use and I got a bell housing off a Dakota, so I think on the trans-side of things I'm all taken care of for now.
I'm not opposed to having my ECU flashed (and that will most likely be my only option since I'm running a manual trans). Are there any downsides to having to get my ECU flashed? I know it might cause a little extra down time while I'm waiting to get it back, but I need to start over on my wiring since I have to find a new harness anyways.
I picked up a flywheel from Summit Racing that I plan on using (part no. PFT-50-2754). It says it works for the 5.9 Magnum even with it being externally balanced?
Can you post some pictures of your cruise setup on the dash? I have a '97 as well, and don't know what the exact manufacture date is on it, but chances are, it's early on like yours so I'll have to do a retrofitting of cruise too.
And final thought, I plan on swapping the rear end on mine. I currently have a Dana 35 in the back. Tired of looking for a Dana 44, especially since you were so against running a Dana 44 behind a V8 (understandably so with your past record of breaking them). I'm now tied up between a Ford 8.8 (controversial on here, I know) and a local Dana 60 on CL. It's not in my budget to swing the Dana 60 from Currie, so I'd be doing all the fab on the axle myself. Do you think the Ford 8.8 will handle the stress from the 5.9 just fine? The main reason I'm shying away from the Dana 60 is because it's so much wider, even though it is a brand new, never mounted axle. And then on top of that (if I don't crop it down to a more reasonable width) I'd either have to get new wheels plus adapters for the front or get new axle shafts that match my current lug pattern. Both of which would be costly. On the Ford I'd just have to get a bracketry kit and then I'd run spacers for it to match the front end. Thoughts?
