DirkDPG
I think you should put your gauntlet away and explain how to tune springs. Anyway, Blaine already made the offer to prove one or the other. Maybe give that a go.
Uhhh-Huh. That's what I thought.
Just to clarify.
Will the Jeep be at the same height with the 2 different rate springs (no spring spacers added)?
You don't "tune" an existing spring in terms of changing the rate. You can add leveling spacers to alter stance or ride height if desired.
Fundamentally, I reject the LCoG build philosophy. And nowhere did I say that all stock Wrangler drivers have undrivable Jeeps.
The assertion is that you cannot swap springs without changing the ride height one way or the other. Changing the ride height changes how the shock behaves by changing it's travel bias. And changing the ride height on a shorter travel shock is going to have a greater significance, for better or worse, than the same ride height change on a longer travel shock.
We know that. How does one choose a spring to tune the ride?
You're avoiding. Stop it.
They can choose spring rates from our website, but most of our customers call to talk through their individual applications and we can determine spring rates based on multiple factors. They do this because they actually haven't installed hundreds of OME lifts and need some help choosing.
It's a thousand dollars bruh. I'm not joking. We'll put our firmer OME coils on a stock TJ and drive it. Then, we'll install a lighter set along with the spacers needed to equal the ride height of the heavier coils to eliminate your shock travel bias argument and let the chips fall where they may.
This is an open invite to any who really believe that coils make no difference in ride quality. If you REALLY believe what you keep on saying, take the bet!
It certainly is. I could explain why OME coils are better QUALITY than Rough Country and some others, but it won't matter. You'll just drag me down the next rabbit hole and change the subject again.
Why guys keep bringing up shocks in this discussion is beyond me. I've been building TJ's since they came out in 1997. FULL-TIME since 1999.
I've been involved in literally HUNDREDS of TJ builds and sold literally thousands of suspension systems. Had multiple rigs in magazine features as well, but somehow folks want to assume that I just bought my first jeep last week.
I have built multiple rigs with "tuned" shocks, as well as higher end adjustable shocks like OME BP-51's, although those aren't what we sell the most of.
I never came to argue or dispute the values of shock tuning. Bringing that into a discussion of whether coil rates affect ride quality is disingenuous...
at BEST!
I know for a fact that I can take a bone stock TJ, set it up with one set of OME coils and shocks, R&R a different set of OME coils, adjust/space to remove any "shock bias" arguments and prove beyond a shadow of a doubt that the exact same jeep will produce a VERY different ride...with nothing but a different set of OME coils.
I guess the only real question is whether anyone wants to put their money where their mouth is and prove me wrong?
I'd even be willing to provide the coils and the place to do it. Bring your video camera and expose me to the world if you feel confident.
What's that you say? You'd be all over that if it wasn't for the expense of getting up here?
How about this- I'll bet you $1000.00 cash on the result. If you are THAT confident, bring your betting cash and your video camera and prove me wrong!
If I lose, you'll have a grand in your pocket, the video proof that I was dead wrong and the supreme right to be the guy who finally put this argument to rest.
So, whaddya say? Yes, let's do it.....orrrr do you just want to keep rambling?
What OME spring would add about 2” of height to my current ride height of 7”. In the rear. My stock springs have sagged. Maybe a 2933/2941 or 2942 OME. Might as well do the front too to even it out.
If you put a firmer OME coil on one side and a lighter coil along with the spacers needed to equal the ride height of the heavier coil on the other, would you be able to feel which corner has the softer spring?
You’re asking for an OME spring that is the equivalent of 1” lift over stock (8”). It’s impossible for any of us to know because lift height is dependent on sprung weight of your rig. The manufacturers advertised lift is just an estimate. A spring advertised as 2” May give 1.5” on a heavier rig or 3” on a lighter rig. That’s why I suggested a spacer. It eliminates the guesswork.
For springs that advertise 1” over stock 8” (2” over your current 7”) you might go back to the spring resources page and look at spring specs.
EDIT: for the rear you might look at H&R 52107, but I don’t know the spring rate relative to stock. The front is hard to compare for the same reason. You can only ask others with those springs what they got, but it still won’t tell you what you’ll get. Thus the need for spacers.
dang that’s a lot of words.
why do we keep bringing up shocks in this discussion? it's because they are the component that will affect ride feel the most. there's nothing disingenuous about bringing shocks into a discussion that is literally titled "rough ride". the only disingenuous thing is you pushing this spring rate thing like it makes as significant of an impact as shocks do in ride feel. that's just silly!
fwiw I’ve already done this experiment over a decade ago. wasn’t trying to win a bet, prove or disprove anything. i was simply chasing a better ride. didn’t like what i had and i drank the OME koolaid. even back then when i wasn’t as knowledgeable i still knew enough to keep one constant variable, the shocks. can’t remember what shocks they were but definitely remember paying for the OME springs.. twice. i still have the spacers i used back then in a box of old parts.
tried the ‘firmer’ springs first, couldn’t get the shock bias right so I added small spacers to get it dialed in. didn’t like the ride so I switched them for the ‘softer’ spring and tweaked the spacers to get the shock bias right again.
the results were this: the placebo effect is a real thing. i talked myself into thinking the ride was ‘better’ with the ‘softer’ spring. my butt dyno was off however as i had 3 roommates and a future ex-wife confirm that i was crazy to do all that work for pretty much the exact same ride feel. i gave it an honest shot and didn't need a $1000 bet to do the exercise. hell, i spent the $1000 happily to try to dial my ride in! i asked my ex-wife if she remembered me doing this last night when we were on the phone and she started laughing about how dumb i was.. and still am
fast forward to now, i’ve had 3 different sets of springs on my jeep this year alone while never changing the shock. none are OME since there isn’t an OME spring to fit the ride height i want, but all three springs ‘felt’ the same. why did i switch out springs twice in a 6 month period? it wasn't to get a better feeling spring that's for sure, i'm smarter than that. just wanted to set my ride height correctly which is exactly what a spring does under our tjs.
i'm not here to dispute the fact that you've been in magazines and have installed hundreds of OME lifts and i'm not disputing the fact that you've sold literally thousands of lifts.. good for you bud i'm glad you are doing well! i'm simply disputing the fact that changing springs alone can dramatically change the ride feel. you can't even make that argument since there's no two off the shelf OME springs that give the same ride height at my current sprung weight. there's too many other variables at play sir and the minimal effect of the spring can't realistically be measured. the $1000 bet would end up being a giant waste of time that would prove nothing.
hey, i used to sell shit that no one needed too.. i sold the exact same thing one could buy at a shop next door, yet i charged 200% more and sold more stock than the other shop. why? i was damn good at getting people to drink the koolaid. keep doing your thing selling whatever it is you need to sell to make your targets, doesn't really matter as long as you have happy repeat clients in the end. just don't come here and claim that you can change only the springs and dramatically affect the ride.. look at your statement here:
that's not changing springs only sir.. just sayin.
Lotta words there as well.
OME had nowhere near the number of coil options a decade ago that they have now, let alone the coils that were never designed for a TJ that work great in a TJ.
I will stand by my point AND my bet. I know for a fact that it is true. You say there are too many variables to prove the test? How can you make that statement? If you take the exact same jeep (same tires, air pressure, control arms, etc, etc) and switch NOTHING but the coils and enough spacer to equalize the ride heights, there are no other variables! It is actually the only way to test this concept conclusively.
I'd much rather have a coil that rides nice and sits right with a 1/2" spacer than a coil that doesn't need a spacer and rides like cr@p!
