3640lb is pretty good.
Empty, no back seat, and a 1/4 tank. I've made a conscious effort to not add weight where I don't need to, but it kind of is what it is.
That was full tank, with backseat
Time for a diet!
Anything I can think of to eliminate might eventually only add up to 100lbs after a lot of work.
Yea I was amazed when you said you weighed in at 4500, your Jeep is one of the more weight conscious builds on the forum…
Changing to an aluminum front bumper and then removing the York OBA and AC system are the big three things I can come up with that might remove less than 100lbs.
What about mounting your spare in the back, and then you could replace the tailgate and hinges in favor for a drop down aluminum tailgate, id imagine you could probably drop at least 50lbs doing that. That’s what I’ve been contemplating as my tailgate is bent from the PO and that stupid tire carrier/basket bs.
Moving the spare into the bed will happen. I would lose the small weight of what currently remains of the ExoGate in exchange for whatever tire mount I build to replace it. From there, the naked factory gate is already not very heavy and I don't want a drop down.
That’s entirely fair, I’m gonna keep track of everything going forward weight wise, where do you think all your extra weight has come from? I could imagine the 44s not helping nor the 241? I intentionally sought out a tj with a Dana 35 because it’s lighter and high clearance as well as strong enough when built properly.
I need to go weigh my shitbox now and see how it comparesF/R 44s, 241, winch and bumpers, 35" tires with hidden beadlocks, bigger brakes, hubs, lockers, full aluminum armor, midarm stuff, shock towers, all add up.
It could be much heavier if several of the things I have added weren't chosen with adding weight slowly in mind. And things didn't start that way in my early days of building.
That’s what I figured
Hidden bead locks?…. Got a page number in your thread on that one, I don’t remember ever reading about it
Coyote internal beadlocks went in March 2023.
Your Jeep is also fat.![]()
Are you Fully loaded out for trail running? I’m sure you know, but spares parts, tools, all that pack out stuff you like is heavy, too.
I don’t think any weight savings will come from the Jeep, but thinking about the difference, I’d bet that is a big one. Blake was probably empty, you probably had your stuff.
