Was that light my fault on spring creek? I have another one that I'm not using now
I'm not sure actually, though I do remember rubbing that tree pretty hard. I have another set on hand, someone cut the plug so I need to do some splicingWas that light my fault on spring creek? I have another one that I'm not using now![]()
Sorry, I used the pig tail for the replacements.some cut the plug so I need to do some splicing
He's all set up for the strip club.Any plans for the Jeep with the winnings of the contest @tworley?
Let's run down Colfax and see what we can piece together.I am debating a redneck version of hydro steering. I need to get a few other things ironed out beforehand.
I'd love to, but last I priced it out redneck would be around $600 and PSC/BMB was pushing $2600To keep costs down? Why not the BMB setup that you can piece from BMB/PSC?
I dunno....if you listen to @mrblaine the redneck version is 600 bucks, then you get to spend another 2600 on top to fix it...I'd love to, but last I priced it out redneck would be around $600 and PSC/BMB was pushing $2600
I'll need to look at some of his posts I did read some posts from 2011ish where he observed repeated success in JV on a particular redneck setup, but that was also 10+ years ago.on top to fix it...
The current kit includes the box and pump. Everything else is all the years of refinements to make it both reliable and feel as good, if not better than stock. It's a very different end result than the Redneck.I'll need to look at some of his posts I did read some posts from 2011ish where he observed repeated success in JV on a particular redneck setup, but that was also 10+ years ago.
Does Blaine offer a kit through BMB that is different than PSC’s TJ kit?The current kit includes the box and pump. Everything else is all the years of refinements to make it both reliable and feel as good, if not better than stock. It's a very different end result than the Redneck.
Yes. He has his own recipe.Does Blaine offer a kit through BMB that is different than PSC’s TJ kit?
I looked at BMB and Mr Blaines kit looks to be brackets, cooler, ram and fittings, not even hoses. You have to get everything else from PSC. So I guess I'm not seeing what is different about his kit.Yes. He has his own recipe.
