ECM's are going to be a problem for our TJ's going forward. Mine failed at about 100k miles and had to be rebuilt. A company out of Florida did a fine job of it for me. Talking with the tech down there, he explained that the components rarely go bad, but the solder on the surface mounts fails due to shock and vibration. It causes intermittent bad connections and makes the computers go stupid. Blows out ignition timing, fuel map and transmission shifting. I've got a manual 2.5, so it was just the timing and fuel that was going wankie on me. Already have a plan and parts list put together for when you can't get rebuilt ECM's any longer. New one's haven't been available for several years. There's directions available online to do your own repairs, but like has been mentioned, it's non-trivial between the potting and the soldering involved. You get lucky with the 2.5. Mechanical distributors and carburetor intake manifolds are still available, and pretty cheap. The gauges and a gauge dashboard insert are still available from VDO.
Would you mind sharing the name of this company? I'm sure that would be helpful to a lot of us.
It's the same problem with the ECU on my old BMW M5. It wasn't the components that went bad, it was the solder that would come undone due to the high heat, shock, and vibration.
I think a lot of people will resort to a V8 swap, a carborator (and fake odb2 computer for etest locations) or aftermarket fuel injection computers and a transmission swap of some sort for autos.
I know a guy who was able to rebuild the tcm on my Mazda and I've seen him working on a 5.9 Cummins ecu. But I've no idea if he's willing to do a jeep ecu. He doesn't seem to like American stuff. (the Cummins uses bosh everything so I guess it doesn't count)
There must have been a time
when we could have said no.
I agree with this. At some point it's going to be impossible to get a replacement PCM. When that day comes, the only option will be a V8 swap, or perhaps by then someone will have come up with some sort of aftermarket engine management system, but it would have to control the transmission as well on the later model TJs with the 42RLE, since the PCM and TCM were one unit on the later models.
