Ray
Chris,first thing i read on this forum and identified with it very quickly.Took your idea and put it to work, it worked great.No more gas smell on my hands when i fill up. Any way this prompted me to sign up.Thank you
How much work is it to pull the tank? I have to do mine, the flapper hose isn't cutting itWhile i had to drop the tank to replace the fuel pump. I was able to remove the stuck valve and file off a slight bit of plastic from the "guides". Works like a charm and it only cost me labor.
How much work is it to pull the tank? I have to do mine, the flapper hose isn't cutting it![]()
@CabbageVendor , so how do you get the damn cage off? Been trying to get it off without breaking anything to no avail.![]()
Any way of going back to the old hose? I did not replace the filler hose with the GM hose. No issues. Could be a problem when using both. I know its a PIA.I pulled the filler hose to check the valve. Moves smooth and freely with very light pressure. The only other thing I can think of is however it purges air when being filled is possibly plugged. Other than that, I am at a loss.
