Hello everyone! Newish here but long time Wrangler enthusiast. I am about to pick up a 98 Sahara Hardtop that has been sitting in a driveway for 15 years. If the frame isn't shot I'm going to go for it. Resto-mod is a bit of a stretch with what we plan to do but we'll essentially be taking it apart, upgrading and rustproofing things and putting it back together.
This will be a father and son build and will become my new daily-driver/weekend toy. I plan on installing Metalcloak Overline's and am wondering if I should go with 33's or 35's. The current suspension is shot as its been sitting all this time with a plow hanging off of it. So are all of the rubber bushings everywhere.
Here are the major plans:
35's on a TJ also requires its own set of upgrades. I'll probably do some upgrades to the Dana 30 but will eventually want to put a Dana 44 in it. I think most of the other complementary mods that are listed above should cover the rest.
All that said....will 1.5" of lift be enough to stuff a 35 on a healthy stock suspension without rubbing using Metalcloak Overline fenders? I'm not 100% committed to Metalcloak either. I want as much tire clearance as possible and will consider other brands if you guys think they offer more room for the tires.
Whatever tire size I settle on...I'll be going with 17x8 rims with a 3.75 or 4" backspacing. So what do you think based on what I've said....33's or 35's???
Thanks in advance!!!
- Rebuild the engine. Probably go the poor mans stroker route.
- Swap the 32RE for an AX-15. It will see alot of highway time.
- Install 03-06 TJ Rubicon Unlimited OEM springs. Probably the 130(FR) and 106(RR) springs.
- Savvy/Currie Johnny Joints all around
- Currie HD steering
- Some sort of upgrade for the trackbars. Either new bars/relocation brackets or new/better bushings.
- Simple/compact steel bumpers, rock sliders, and corner guards.
- High clearance tube fenders such as Metalcloak's Overline's.
- Vanco 17" big brake kit.
- 1.25" solid body lift in preparation for a future tummy tuck.
- Regearing to be at about 2500RPM at 70mph with either 33's or 35's.
