Diff side? What method did you use to get it out?
Passenger side. I have a puller, but it requires you to remove the center steel sleeve. I could not get that out, so I used a cold chisel on the inside of the bracket to break the bushing free. Went around the bushing with the chisel until I could get the air hammer between the bracket and bushing. Two bursts with the air hammer and it came free. It really wasn't hard, there just isn't much space to work with.Diff side? What method did you use to get it out?
So you’re keeping it?
Today anyway he is, tomorrow is still undecided![]()
The LJ will stay with me. I don't see that going, unless I'm gone! The TJ will be sold at some point, but I'm not actively looking to sell it now. I'm still planning to retire at the end of the year, which will make me reevaluate all my plans!
Wouldn’t you want to save the work of the mid arm for the LJ?
It wheeled fantastic, with the only real issue being the bent ZJ steering.
This thing continues to fight me every step of the way. I spent an hour today removing the bushing in the center housing. I've never had one as stubborn as this!
First, I lied. Second, I'm going to have to step away from this Jeep for a while, before I decide to sell it and buy a Honda or Toyota!![]()
Still DW?
The persistent problems that you can’t figure out are the worst.
