To many people are over building for there driving skills. I have been one of them and the rig out drove my skills and I ended up in the hospital for a month..
Real good advice, this.
If the A pillar isn't down tubes that hit the floor, you are seriously overlooking good "cage" design. But there again, you ain't gonna climb in through the window so there is more than a bit of compromise anyway.Alright, in the interest of my driving and fabrication skill levels (and cost), I'll pull back to 35s for the first major upgrade. Going this route, I'm not replacing the axles. I'll build the D44s I have.
Major components I can think of for now:
1) Full cage: Safety first! I've been planning the GenRight kit, but I'm not eager to have the cage holding the dash in. Thoughts?
Good suspension has practically zero to do with ride quality in reasonable lift parameters. Focus on shocks.2) Suspension: I like the factory handling, but I'm not a fan of the factory ride. How much more lift? Coilovers? Outboard rear shocks? Long arm or mid-arm (same thing)? 3 link? 4 link?
Hard to beat the Rock Jock geometry with some hydro assist.3) Steering: Change geometry? Hydro assist? Has to be stable on pavement.
If you need to truss the axle, you have the wrong axle, go get the right ones. Gears are axle and transmission dependent. 42RLE and 35's in 44's require 5.38's.4) Axles: 5.13 or 5.38? ARB lockers or electric? Larger shafts? Cro-mo? Truss?
That isn't as much fun as you think it is.6) Fuel tank: GenRight, larger capacity.
Lighter is never not better.7) Armor.
This is already feeling a lot more manageable, thanks for the feedback so far!
I do agree building around a 35 first would be wiser. The photos you posted is nothing extreme enough to want 37s.
Like Starkey said he goes everywhere he wants on 35s. Judging by his pics he might end up in the "tons and 4ds" club but he's learning how capable his rig is now and improving driving skills.
I agree, the A pillar needs to hit the floor. Are you recommending tubes through the dash rather than the door brackets to accomplish that?If the A pillar isn't down tubes that hit the floor, you are seriously overlooking good "cage" design. But there again, you ain't gonna climb in through the window so there is more than a bit of compromise anyway.
Fair enough, but the suspension determines what shocks I can use. If I decide on coilovers, what is reasonable lift with 35s? How much flex can I achieve?Good suspension has practically zero to do with ride quality in reasonable lift parameters. Focus on shocks.
Is that the CurrectLync? Or crossover?Hard to beat the Rock Jock geometry with some hydro assist.
NSG370; I choose when to shift. Quadratec says 4.56, Omix-Ada says 4.88, Interco says either one. I lean towards 4.56, thoughts?If you need to truss the axle, you have the wrong axle, go get the right ones. Gears are axle and transmission dependent. 42RLE and 35's in 44's require 5.38's.
Why wouldn't I want a larger gas tank? Or is it a low cost/benefit ratio?That isn't as much fun as you think it is.
So, aluminum?Lighter is never not better.
So, aluminum?
I did not stutter, or mistype.I agree, the A pillar needs to hit the floor. Are you recommending tubes through the dash rather than the door brackets to accomplish that?
Not really. The only reason to go to coil overs is for packaging.Fair enough, but the suspension determines what shocks I can use. If I decide on coilovers, what is reasonable lift with 35s? How much flex can I achieve?
Crossover sucks. Avoid it on the stock axles.Is that the CurrectLync? Or crossover?
No thoughts whatsover. I don't have the energy to correct all that is wrong in that statement.NSG370; I choose when to shift.
You can't get a bigger tank without putting it where it has the highest detriment to ground clearance.Why wouldn't I want a larger gas tank? Or is it a low cost/benefit ratio?
Yes, or none.So, aluminum?
This thread went in a surprisingly better direction than expected.
What is the ultimate goal?I live in Reno, an hour from the Rubicon and Fordyce. Been on both, just not in my rig. But that is the penultimate goal.
lean towards 5.13s ... 4.88s if you are RPM averse and routinely drive at 70+mphNSG370; I choose when to shift. Quadratec says 4.56, Omix-Ada says 4.88, Interco says either one. I lean towards 4.56, thoughts?
What is the ultimate goal?![]()
StockI need to get a full cage in before next summer, what are people running?
Stock
Nope. I’ve seen first hand how sturdy the front tubes aren’t.
5-point harness when I start serious crawling (need cage first). Factory belt for now. No plans for high-speed off-road.What are your plans for head and limb restraints?
Probably find a custom shop near you and get a cage built with tubes through the dash and not the stanchions that most manufacturers seem to be going with.
