Thanks for elaborating. Sounds like the biggest risk of adding a cage is that it's not a "true" cage but feeds overconfidence like it is.
Cages are like pregnancy, you are or you ain't. It is a cage or it isn't.
Ok, enough about cages.
Shocks: How can I test the RE shocks I have that probably have over 100k miles on them?
If you want to go wheel with rigs on 40s in a 35s build, you want to make it a nice 35s build. So I’d look into some 12” fox remote resi shocks with Poly towers. You want 12” in the rear and 11” up front
To confirm, those lengths are with the 3.5” lift?
My experience is I've always rock crawled with people who abandoned sense and reason long ago. I've been upside down in several rigs, and the worst damage was a dented tube and scratched paint. I've seen stock cages completely demolished in similar situations. I'm just trying to keep me and my passengers safer. Obviously part of that is "not driving like an asshole;" is it actually all of the answer?
No. Those are the lengths you build the shock mounts for.
Not in the budget yet, suggest something for a short term replacement?
Pick your poison. Anything bolt on will be varying degrees of vague and adequate.
To add, there isn’t anything out there that performs well, that also bolts on. You pick what garbage you want to live with until you can take it no longer and you spend the big money on tunable shocks
Sounds like monotubes are not worth the extra cost at this level.
Got it, outboard the rear shocks.
I've got a rig here with correct length Rancho 9000X on it. I'm practically certain I can convince the owner to trade you a dead cat in a box for the whole set. I've ridden on some of the worst shocks ever and these make them all seem stellar in comparison.
Ever tried KYB Monomax shocks? My first TJ had them from the PO with a 4” lift. I think replacing them with solid bars would have improved the ride.
I did not hate the Rancho 9000X, but I wouldn’t pay to run them again.
What about Bilstein? They have a decent rep…
I would like to get input, especially from @mrblaine, since you sir know alot !
My question regarding running a cage with a 5-point harness on a daily driver, Would it pose a greater risk to run such a roll cage and 5 point harness compared to stock when it comes to daily street driving, im assuming the harness and roll cage would help out better in an accident compared to the stock seatbelts and cage if it were a really bad cage
I want to make sure that my jeep and myself are protected in case of a roll on the trail if shit were to go south. I would would need/want ties that go to the frame, bracing behind the dash, and potentially keeping the stock B pillar bar since its stronger than what anyone would want to replace it with, removable door tubes since there's dom tube couplers/connector deals (note i would have them on when offroad)
I want the cage to protect me, but not solely to encourage me to take dangerous lines. My concern is whether having a built roll cage for daily driving would pose a greater risk compared to the stock cage. Would adding proper padding make it safer in case of an accident on the street? I understand that no one can predict the future on weather you'd survive a crash with either 5 point harness and cage setup vs. the stock setup, but I would appreciate any insight on the safety of a built cage and 5 point harness on the street compared to a stock cage and seatbelt setup.
I have seen cases where people roll over and barely make it out alive, and it seems like a good cage and harness could have prevented that with the only thing happening of said person would've been some scratches and a hard earned lesson on the trail
