Was under the impression that 4.56 was "the best", ...
The longer you stick with this, the more you will figure out that there is a lot of popular bad information out there.
I put my hands on a set of Revolution Dana 30 5.13's that had a stripped pinion, and decided to go for the 4.88's instead.
Something about seeing it side by side with 4.88's turned me off.
That's upsetting.
I debated on 4.88's vs 5.13's for 2 months, and finally pulled the trigger on the 4.88's.
Paid for, and parts are on the way, as well as ARB's.
Was under the impression that 4.56 was "the best", but being in CO and liking trails I decided to go deeper.
Thought the 200rpm difference wouldn't hurt much. Maybe I goofed.
I guess I'll run them awhile, and swap out later if needed.![]()
I wasn't about to steal the opportunity from you.![]()
Some of it is old too, right? Wasn't 4.88 the deepest you could go in the 30/35 for a long time? So you can't read stuff too old
I've done what I could in weaning out the bad info.The longer you stick with this, the more you will figure out that there is a lot of popular bad information out there.
hiring it out because I don't know enough about the process of re-gearing to feel comfortable tackling it myself.Are you doing the regear or hiring it out?
You guys have thoroughly convinced me.
Just to note, I initially was dead set on 5.13's, but got cold feet last minute, and went for 4.88's.
It's lingered in my mind for awhile though.
Going to shoot a call to the shop handling the install tomorrow, and get them swapped around.
There's a ton of it though.
Hence why I chose to join the forums, versus Facebook where I was previously gathering info.
(absolute shit show by the way)
$1550 out the door for both axles Re-Geared + all new seals (w/ 2year warranty on the work)
plus additional $1,050 per ARB (install included since the gearing will be out anyways)
What shop is doing the work? I had mine done at The Diff Shop.
All the gearing discussion is interesting. Back in the day when TJs were the current jeep model we’d only go the step lower recommended gearing(say 4.56 vs 4.88) if we had a standard because it had overdrive. I ran 33s, 35s and eventually 37s all on 4.56s with a 3 speed auto and 3.8 atlas. I never liked super low gearing though and I live in Texas where it’s flat. All three tire sizes with 4.56s and it would still blast down the highway. This was the guidelines we used back then.
31s 3.73
32s 4.10
33s 4.10 or 4.56
35s 4.56 or 4.88
37s 4.88, but 37s were considered huge tires when this information was relevant.
I’m not even sure we could get 5.13s to be honest, no one in our group had them or even discussed them.
This is not advice just a little anecdotal information from a group of us TJ folks back in the early 2000s. My current TJ build is staying 31s and stock 3.73 gears so I don’t have to really consider it for now and my JKUR has 5.38s and 37s. I’d go lower on the JKUR if I could hahaha.
Anecdotally, this is exactly the bad thinking and methodology that still plagues gearing discussions to this day. It was incorrect 25 years ago.
My dad is of a similar time period and was taken aback when I told him I was regearing to 5.38. He was still flustered after I explained that with the tire size and transmission, the rpms were only about 2850 at 75mph. Then he had to wrestle with the idea of driving a Jeep on 35s comfortably at 75mph.
Axle work is scheduled to happen on Thursday of this week.
I've been procrastinating the "perfect" on-board air setup.
Found this ARB on Facebook Marketplace FOR $150.
Guy installed it onto his JK, pulled it back off, and chose to run a twin model instead.
Thing is practically brand new.
$100 cheaper than online/new pricing, and works out great for me because I was swaying the direction of running 2 compressors anyways.
(One for lockers, and a separate one for on-board air)
I know the basics of how it should be installed, but if anyone has any pointers/tricks, or anything you wish you'd done differently for the install, feel free to shoot them at me.
For now, I'm happy.
That's the best way to run ARB's. Solenoids mount straight to it, can't get much easier.
I've always gutted the ARB wiring as I run mine with a spod.
It's no good for anything other than lockers so you'll definitely need another compressor for OBA.
