Basket's Build
Your hitch may have a sticker saying what the weight ratings are both with and without.
Half tons most should have one. Larger it depends and I’m not familiar with the impact of the extension you’d need.
Also, assuming the distru one is the higher one,
7500lbs limit on normal hitch
12k on distru hitch
Reactions: reddvltj
12k on distru hitch
Yes, if you’re over 7500 lbs for trailer and jeep then you need one.
What is the difference between "weight carrying" and "weight distrubiting" hitch.
AND why the fuck did they use two shades of green for the two I can't tell the difference whatsoever
Weight carrying I believe is a standard hitch like the weigh safe you linked.
Weight distribution has torsion bars which provide weight transfer to the front and sway control in some hitches. Much more complicated.
^^^^ This!!
Weight carrying is just a hitch ball. Your back bumper is a weight carrying hitch of sorts.
When most people think of the word hitch, they think a receiver style hitch. The receiver is what bolts to your vehicle, the ball mount is either weight carrying or weight distribution.
Like Ryan said, the hitch with the weight scale on it you posted is a weight carrying ball mount....
This is a weight distribution ball mount and spring bar set up. (one style anyway)
Sway control is usually an aditional bar that goes between the hitch and the trailer frame that you can adjust the about of friction there is for the bar to slide and allow turning. You tighten it up for driving down the highways, and loosen it up for city driving.
Here's a Curt anti-sway bar control kit... The amazon link has some pretty good descriptions for the hows and whys...
https://www.amazon.com/CURT-17200-Sway-Control-Kit/dp/B000HLO7QA?tag=wranglerorg-20
^^^^ This!!
These are good descriptions thank you!!!
I guess i'll just have to weigh the jeep and trailer and find out if I do need the distru or not.
and for the sway... when I towed the mr2 and audi, I can't remember anything that I would call "sway" during the drive. So I'm just gonna assume I don't need an antisway setup until I start to think I do.
I can already tell you, that you will need one if you are going to use a hitch extender under your camper.
You will also need one that is designed to use with the hitch extender.
I would only use an extender like the one @Wildman posted.
Reactions: lBasket
^^^^ This!!
Equalizer is weight distribution and sway control in one. Which looks to be the one you posted. I liked mine on my F150, no need on the Superduty.
https://www.equalizerhitch.com/
Reactions: lBasket
I was honestly hoping to get away with not using a hitch extender. But that'll depend on what trailer I get, ultimately
Reactions: reddvltj
I think you’ll have to have an extender or you run the risk of the trailer and camper coming in contact with each other in non flat situations.
Distribution or sway control?
He was eluding to needing the equalizer hitch... a sway controller isn't always a need... it depends on how you set up your tongue pull trailer. If you end up with a close to equal weight bias front/rear on the trailer I would definitely want a sway control. It's too easy for the tail to wag the dog...
Reactions: Mike_H
You're going to need a hitch extension PERIOD. Your camper hangs over the back of your truck way too far. This one is 18" long and with a weight distribution hitch it's good for 6500lbs. But it cuts whatever your hitch its rated for by 50%. So if you've only got a 10K then it's only good for 5K. This is one of the reasons I decided not to get a camper for my dually. I knew I'd have to have a 36-42" long extension and it really bothered me the thought of having that long of leverage off the back of my truck. It was also part of why I'd built my Redneck Toyhauler before.
Think you could modify the moving bed to be able to mount on a Hawse fairlead and mount a winch still at the front of the trailer? That way you can pull a disabled Jeep onto the trailer...
Just a thought because I've seen a few Jeeps winched up the ramps onto a trailer after being unable to drive on under their own power. Good way to 'future-proof' this type of trailer. Winch is usually a smaller ATV-sized winch to just pull a dead-weight vehicle (non-recovery).
I think you could put a roller in the middle front of the tilt section and be able to have a winch mounted there.
Not always... sway control may come with some but sway control is a separate piece of the puzzle.
I'm pointing out the Equalizer is both, incase Basket were to need a WDH.
Integrated Sway Control Provides a Safer, More Comfortable Ride​
The Equal-i-zer hitch eliminates the need for add-on sway control devices and the hassle that goes along with them. With an Equal-i-zer hitch, you don’t have to worry about restrictions on backing up or a tight turning radius. There’s nothing extra to hook up or take off. When the weight distribution is engaged, the sway control is engaged too, providing your family the best protection possible.
With every Equal-i-zer hitch, you receive:
  • Weight Distribution Shank
  • Patented Weight Distribution Head
  • 2 Sway Control Brackets
  • 2 Spring Bars
  • Snap-up Lever
  • Spacer Rivet and Washers
  • Hitch Pin and Clip
  • Necessary Installation Hardware
  • Limited Lifetime Warranty
Reactions: josb612 and lBasket
