Manual trans? That'd make 200 whp easier right?
It would, but what fun would that be. It's a 32rh.
I'm not revving high at all. My trans is programmed to shift at 5k. I think the hard cut is 5600. Those were the springs he sent with it. Comp 26125. The ones I got are 74813 which is actually a Lunati part made by Comp.
Just curious if you had anymore input on these. I'm finally starting to get parts together to install my Russ built Eddy head and was considering installing these springs first.
Did you catch my question on your valve springs?
i wonder if Cryogenic treatment could help resolve this ?Sorry I missed it somehow. I am undecided on the springs. They work fine no issues, but I am still getting the same amounts of bearing material in the oil. Last oil change I cut open the filter and found a few nice size chunks. I almost wonder if my cam is bent. I remember the machine shop saying they had to straiten it after the first rebuild. It's a nitrided comp. I spoke with another cam company that told me nitriding is hit and miss with cams. I guess it can cause internal tension that bends the cam over time. Right now it's running fine so I'm not overly worried.
I as well have seen a glazy metallic sheen on my cam from Comp too ! My 1st cam bearing was kinda chewed and i suspect it was the very stiff springs that clearwater put on the head (That I ruined head while porting) So i just put back my stock head that i cleaned up and ported and ill see how my next oil changes are like with the stock head with the stock springs of course that'll handle .450 lift and so far no problems !I have metallic sheen in my oil and a nitrided cam as well fwiw.
I think maybe it's not possible due to engine architecture?
This warp over time stuff is new to me. I also have a nitrided comp cam
Yeah, warping hasn't been my issue so far. It's eating lobes off the cam.
If this is an ongoing, repeating issue, have you checked for other causes, like stuck lifters and out-of-round lifter bores?
I may be wrong, but I believe any warping occurs during the nitriding process, and the cams are straightened to a spec afterward. Since the cams shouldn't be reaching anything near that temp inside an engine, any warping issues should be present out of the box.
Billet dual roller? As in a true roller cam (as opposed to flat tappet)?
Are all the cams in question Comp Cams ????
