thanks for the reply! looking into the aluminum ones. does it require cutting of stock fenders? mine are rusted to hell lol
You can replace the entire front fender, but you then have to add an inner fender - which you can also get from Genright and is what I run. This allows you to sell the original fenders intact and recoup some money. The Genright inner fender design also provides more space under the hood compared to using the stock inner fender - as discussed below.
The other option is to cut your existing fenders and basically install the highlines over the cut fenders (you also raise the existing fenders to meet the highline) allowing you to use the stock inner fender. This works - but for me using the Genright inners was a much better overall solution.
