I had a weird issue pop-up yesterday.
I cranked the Jeep to get it into position to rinse all the mud off, but it was making a chattering sound. I quickly isolated the sound to the arm of the tensioner pulley bouncing. It was fine the day before when we went fishing.
A closer look revealed that the bolt holding the pulley to the arm is rubbing against the block (timing belt cover?). As a reminder, I have a York Mini OBA system using Off Road Only's install kit, so my tensioner is installed in a non-OE location. I reached out to Steve to see what he thinks and expect a reply shortly based on previous experience with him. I wonder if the ORO bracket shifted a tiny bit under use, which is causing the problem. The ORO bracket reuses the four OE alternate bracket holes plus two more previously unused holes, so it should be on there pretty good unless I screwed up something during install.
The cause of the chatter is the rubbing of the bolt head against block causes the arm to flex roughly between positions, resulting in a clicking sound. There is enough friction between the bolt head and block that, with the engine off, I can move the arm to a position and the friction will hold it in place until I move it so far that the tension from the belt suddenly springs it back to where the arm is resting against the stop. The belt is a very tight fit, so it is pretty much at or very near the stop when running. You can see it do this on its own with the engine running.
This first photo shows scratch marks left by the bolt head. These only became visible after I manually moved the tensioner arm enough to make marks outside the radius of the pulley.
This photo is the best shot I could get of the bolt head as it relates to the pulley and block. I wonder if I installed something wrong here... I think there is a washer between the bolt head and pulley bearing that was required to keep the pulley in place. A thinner washer or thinner bolt head would eliminate the problem. This is the OE arm and pulley remounted on the ORO bracket. A tiny spacer under the arm where it mounts to the bracket would likely solve the problem too.
