I made a silly mistake and ended up with the worlds crappiest supercharger
instead of an OBA system. I thought I had looked at the photo showing the intake and output of the compressor and connected my lines correctly, but i had them reversed. The last thing I did today was test the system. I could not understand why, when I triggered the relay (no switch connected yet, just sticking the trigger wire on the battery), the clutch would engage but I would get no air. Messed with it for a few minutes and everything seemed like it was working right. I finally looked at the instructions again and realized I had the in and out swapped, so I will need to fix that tomorrow. The only bad thing is the cut I made in the vent hose for the T is now the wrong place. I have some barbed splice fittings that should fit the hose, but it's annoying that it is going to now have the tee and a splice just a few inches apart. Maybe I'll buy a new piece of straight hose and reroute the whole thing using elbows, so it has more clearance from the compressor or just leave it with the extra splice.
Here is everything else I did today before I made the realization above, I had finished connecting the hose, mounting the relay and running and dressing all the wiring. I then started mocking up some of the air distribution and finalizing where I would mount it. Here it is just resting against the inner fender above the driver's side battery tray. I will use the remaining space for another manifold for the solenoids and distribution system.
The tank is from Hadley Horns. It has two threaded studs, two ports on one end and one port on the other. I drilled the inner fender to accommodate the studs, but wanted to space it a bit so the studs would not protrude too much and also provide some sort of cushioning (probably not necessary). I had some hose left over from earlier (that I probably should have saved due to the unknown to me at the time mistake I mentioned at the beginning of this post, but there is still some left). So, I decided to make some rubber washers from it. I used some punches that we use for other things (I also have heart shaped punches) and a leather hole punch to make rubber washers.
Here are the washers and some stainless fender washers mocked up in the threaded studs. When installed, from outside-in it will be:
nut - washer - inner fender - rubber washer- fender washer - rubber washer - fender washer - tank
This gives me the spacing I want and minimizes steel-to-aluminum contact. I'll slater the contacting parts with anti-seize to be safe, as I have with everything else contacting the inner fenders.
Next thing I need to figure out is how to get the manual drain I have connected to the bottom port. The drain kit is supposed to be 1/4" NPT, but I think it is larger. The Hadley tanks did not come with any instructions, but their website says '1/4" fitting provided.' Hadley. Google says 7/16-24, but that is definitely too big. Searching the forum for "Hadley" had several hits, but nothing I could find about the fittings. When I tried threading the plug from the tank into my thread checker, the closest fit was M10, but it was loose. The threads are visually a little finer than M10 and the overall diameter is a tiny bit smaller. I may have to go to the store with the parts and do trial and error until something fits.
