The frame bolts will still work themselves loose from the flexing and twisting of the frame. Mine have been doing the same for years no matter what I do.
Green loctite will solve that problem!
Has anyone considered using Flanged Button Head Screws? The flange is 26mm wide. I'm thinking these might be more resistant to rocks sliding down the frame.
What do we do when the surrounding bolt head smears through the hex head?
I like those. I don't know that I like them enough to pay 5 bucks each though.
FYSA during the TJ Fest at Moab this last week a couple of us (me included) kept having issues with skid plate bolts rattling loose. I caused my issues...I used antisieze and grade 3/5 washers. Went to Walker's hardware, replaced a couple of bolts and bought grade 8 fender washers and extra thick washers for a double stack plus blue loctite.
I also emailed UCF because someone mentioned the skid was supposed to come with slotted washers...UCF confirmed it doesn't and they recommend blue loctite and torque to 50 ft lbs.
View attachment 615248View attachment 615249
This was my solution for my UCF aluminum skid. Not as thick as a bolt head and slides over rocks easily. I still check them frequently.
I made them from a 6 foot piece of .25" strapping. I cant remember if they are 1.25 or 1.50 wide .I would have to measure them to be sure. I made a couple sets for guys here in AZ a couple years ago.Did you buy those strips or cut them to size?
Love links to the UMHW and bolts.
I will look for the hardware link.UMHW
Not quite. Separate washer adds a minimum of 2.3mm to the head height.A washer under a standard button head does the same thing…
Sorry........What is UMHW?
Here are the bolts and counter sink I used. I have no info on your UMHW.Love links to the UMHW and bolts.
Is this actually a concern if I already have a 1.25" body lift?
