Switched out my black headlight bezels for chrome in the quest to make the white look more balanced (I’ve had them for some time). I plan on putting a washer behind the steering stops later tonight as my Duratracs rub.
Let's here what you've done to your TJ today!
I'll start by saying I gave her the biggest, most thorough cleaning possible!
I painted mine right across including the corners (a few years ago).. that air vent panel just pops out and make it easy to spray tooSpray painted the few things black like the cluster cover, center bezel, steering column cover, airbag cover and vents. Looks much better then before.
Changed the shift knob on my 32RH. Will try to get some pics and part numbers this weekend while replacing my 4.0 cylinder head.Man, that tire cover is ugly
Good looking jeep
Chrome always gets a like from me!
Finally "finished" my morryde tailgate reinforcement/hinge install so I could put the 33" on the back. I say "finsihed" because the the lower right bolt into the tailgate for the hinge spins freely. I either stripped the threads or whatever bracket the bolt goes into broke free. I'm going to have drill a hole in the back of the tailgate to investigate, I expect I'll be putting a nut on the back of the bolt. I will say this product is built like a tank, really impressive. Closes and opens nicely, well packaged, and all necessary bolts included.
I’ve been curious what all options there were to strengthen this area. Where did you locate this from? Is it much different/cheaper than an exogate?Finally "finished" my morryde tailgate reinforcement/hinge install so I could put the 33" on the back. I say "finsihed" because the the lower right bolt into the tailgate for the hinge spins freely. I either stripped the threads or whatever bracket the bolt goes into broke free. I'm going to have drill a hole in the back of the tailgate to investigate, I expect I'll be putting a nut on the back of the bolt. I will say this product is built like a tank, really impressive. Closes and opens nicely, well packaged, and all necessary bolts included.
I like the factory chrome look on mine as well.Switched out my black headlight bezels for chrome in the quest to make the white look more balanced (I’ve had them for some time). I plan on putting a washer behind the steering stops later tonight as my Duratracs rub.
Dropped it off the get 4.88's, e-lockers, front axle u-jounts, and ball joints installed. Hopefully I'll like the 4.88's with 31's.
Are you sure you posted this in the right threadTotal: 1,400,500 dollars
It’s literally the exact same thing as the exogate, and the good news is I didn’t strip that last bolt hole after all. Project done!! Edit, extreme terrain had the best price I foundI’ve been curious what all options there were to strengthen this area. Where did you locate this from? Is it much different/cheaper than an exogate?
Wanna sell me your black bezels?Switched out my black headlight bezels for chrome in the quest to make the white look more balanced (I’ve had them for some time). I plan on putting a washer behind the steering stops later tonight as my Duratracs rub.
View attachment 50824 My hinges were faded and beat down by the sun so I cleaned em up and painted them with truck bedliner. (Did the side mirrors also but didn’t take a pic)
I’d like to see the mirrors done in Berliner... they just kinda look plain to me sometimes. Maybe it’s the size? I feel like the texture would help
2005 RHD TJ Sport
2010 BMW 528xi
I did the steps also.I’d like to see the mirrors done in Berliner... they just kinda look plain to me sometimes. Maybe it’s the size? I feel like the texture would help
2005 RHD TJ Sport
2010 BMW 528xi
