I figured if the control arms were extended and new mounts were welded on the frame to support the longer control arms, that would bring that instant center line down, closer to the purple antisquat line. Or in my mind, it looks like if you extended the wheelbase enough, you'd eventually bring the instant center down further.
It seems to me that the further up you go with the lift, the more of an angle you have with the control arms. That instant center line is relative to the angle of the control arm angle (from the way I'm looking at those images at least), so this is where I'm getting my thought process from.
Let's keep things a little simple. The moment we start extending the wheelbase, we are in a whole different type of build.
Moving mounts is the correct approach. What happens if you were to flatten the arms? What happens if you make them more parallel to each other?
