It doesn't. The outer sleeve that rotates around the inner sleeve. Unless I missed something. I haven't watched the videos for maybe a year.
Watch it again and see if you can see the confusion I'm having with it.
I wish @mrblaine were still around to answer that, because I know he'd have the right answer. I'm not going to profess to know the answer unfortunately.
Watch it again...
Yeah, I see your confusion. I think its just a poorly worded commentary. Think about it like a sealed bearing. The inner sleeve of a bearing rotates freely too. Lets use a bike wheel for an example. The bearings on a bike wheel rotate freely. But once you tighten down the axle between the forks, that inner sleeve no long rotates. However, now the whole tire rotates inside the fork. So now just press the outside of that tire into a GIANT control arm. The control arm will rotate freely around the inner sleeve that is held tight to the mount.
At least thats how I understand it.
EDIT: We will run into issues though if the outer sleeve is the same width as the inner sleeve and both get tightened up against the mounting surface.
Yeah, I see what you're getting at. The ends of the teflon sleeve will "clearance themselves" once enough wear has allowed it to move more freely. Sounds like premature wear to me, but I guess it won't hurt the overall durability of the joint and is the sacrificial lamb of sorts?
It's nice that you don't have to lube the joint, but don't you think that over time that teflon inner sleeve will wear to a point that play will become present between the inner sleeve and the teflon sleeve?
If a jeep is traveling down the Interstate at 80mph and hits a 6" deep pothole, how much force is transmitted back to the mounting bracket. For those of us who have to drive our Jeeps 1000+ miles across the country just to get to the trailhead, these are real issues. Its not just a matter of some annoying NVH. What happens at highway speeds?
To sum up a rather long post. What is the impact of NVH on the mounting brackets and hardware over long term periods in harsh conditions. How much vibration and stress does it take for metal to fatigue? Can a control arm hitting a pothole at 80mph produce enough force to rip a mounting bracket loose? What if that mounting bracket has suffered metal fatigue over thousands of miles?
If I was just a rock crawler I would go with the JJ. But because I think the DDB will offer better ride and NVH charateristics while being maintenance free it has my attention. Most people overlook the maintenance free part because of the unknowns. So that is why it really comes down to NVH I think. And that is why we have threads like this.
The TJ style control arms and mounts have been in use since the 1984 XJ. Many of these are still on the road with very very high mileage. Are there reports of the mounts failing from fatigue? I don't know the answer, except that it isn't something that ever comes up as a problem.
This assumes that there is a percievable difference in NVH between bushing X and joint Y. If there was, then why are the track bars offered by the companies who make this claim not treated similarly to their control arms to reduce NVH?
At which point, you are left the choose control arms for other reasons than ride quality.
FWiW, I'm not the only one who has performed little to no maintainance on their JJs.
My critique is not about Currie or another company using an appropriate joint or bushing for the desired purpose. It has everything to do with honesty and calling into question the marketing claims and the beliefs that the construction of the control arm bushing or joint has a perceivable affect on NVH. This is why I am making the point to include the track bars as a control arm. If the control arm design matters in this particular regard, then treat the track bars the same. Otherwise, quit the marketing BS and be honest about the inconsistency.
If NVH is not a real world issue, then what remaining criteria are you using to select a joint or bushing on the basis of actual function? Misalignment capabilities? Durability? Ease of maintainance? Do you place value on a bushing (or maybe a joint) that has vestigial characteristics whose purpose was to support a false claim, but cannot be used in a similar application where it's use to support that claim would also apply?
As far as the control arm mount failing from the increased micro-vibrations of aftermarket arms, when does this happen? Yes, the pool is smaller than the remaining OEM configurations. But for as much as people want to complain and find reasons to not like like a particular brand or part, we don't read about this being an issue.
.. I would prefer if they kept their focus on what they are trying to achieve. Which I believe is flex. If the reason for the Duroflex is to get more flex out of it due to using a narrower housing then just say so. Don't make up a bunch of marketing BS.
Metalcloak has done the same thing in some JK threads comparing their suspension to AEV. Saying they handle just and well and have more flex. But that is simply not true either. The 2 products (AEV vs MC) engineered their suspensions for different purposes, and I think they each achieved their goals. But I don't like how MetalCloak says they achieved their goals and also handle better than AEV. Distributors that sell both products have flat out stated AEV is better on the road. It seems like the same tactic they use with their joints.
Keep in mind too, the OEM arms have flex designed into them, so a Clevite bushing provided enough support for said design. aftermarket arms don't have that flex, so a bushing/joint needed to be designed to compensate for that loss of flex. The misalignment kool aid that many drink is just a byproduct of the designs they had to come up with to satisfy that flex. I mean come on, 30* of misalignment? Do you really believe that your suspension can use that kind of misalignment? Hell, even a built to the hilt buggy might use 10* - 15* tops! The NVH kool aid is the other tactic they use, so that is the reason I started this thread. There is no hard data that I can tell, so far. It's fun to talk about though, and gets those neurons humming.
I'd like to take a factory arm and see how much actual flex it provides, especially compared to say the Core tier 1 arm with dual clevite bushings. In another thread Blaine said he felt the Core T1 arms with clevites would provide plenty of flex.
