Picture of what you did?I did it a few years back also. I cut and welded in to delete the fender mounted units also. Love it.
That sounds like a good plan @CasperLLY . I guess now is as good a time as any for me to learn to weld n do some body work. :-/My plan was to weld in flat piece of metal then bondo to smooth out and shape
Sent from my SM-G950U using Tapatalk
Gotcha, to avoid overheating the metal too much in one spot i assume, thanks for that tip. This should be a fun project, or two!Will do. Just FYI when you weld the plate in you'll want to spot slowly from side to side and top to bottom till you are all the way around
Was thinking the exact same thing.My plan was to weld in flat piece of metal then bondo to smooth out and shape
If you like the CJ look, why not the CJ turn signal lights vs the JK lights.... just wondering.Today I ordered a pair of amber jk lights to go on my 05 Sport.
I like the cj look.
I may have my cj and jk and yj mixed up. I wanted the smaller of the two lights, i hope i ordered the right ones.... :-/If you like the CJ look, why not the CJ turn signal lights vs the JK lights.... just wondering.
Yes i plan to @lowranger. Its either do the body work myself or shell out $300 + for flat front fenders. The wallet says i get to do the body work.Looking forward to see how your fenders turn out. You going to do the body work yourself KCsTJ?
Nice! Glad you are going that route, will give it that more of a CJ look. Can't wait to see it. I wish I had the skills of a body and fender man.Yes i plan to @lowranger. Its either do the body work myself or shell out $300 + for flat front fenders. The wallet says i get to do the body work.![]()
I don't have the bar and off road lights that you do. The lights would be visible on my rig with my winch.Anyone that has done this...Are the signals visible with a winch up front? I would like to do the same, but looking at the front of my jeep, there isn't much visible real estate available...
That was my concern, the only downside is bumper accessories could get in the way of the cj lights.Anyone that has done this...Are the signals visible with a winch up front? I would like to do the same, but looking at the front of my jeep, there isn't much visible real estate available...
