You can NOT do that on a stock width axle with 35's.
So does that mean I won't be able to properly go to 35's on my Rubicon D44s?
Your Rubicon 44's came with MOAB rims from the factory. If you put 35's on them and bolt them up, what happens when you go lock to lock offroad or in parking lots?So does that mean I won't be able to properly go to 35's on my Rubicon D44s?
So now you don't care about your scrub radius?I don't know since I don't have the factory rims or 35" tires yet. I'm guessing they'd rub so I was planning to get rims with 4" or 4.25" backspacing.
Even with 33s, on stock Moab rims, it will rub at full lock. You need either wheel spacers or washers on the steering stops to avoid rubbing with 33s, 35s will be that much worse.
Spacers do, washers don't.Which will disrupt the scrub radius.
Kind of a stretch here, but a man can survive on Doritos and Mountain Dew for every meal. Doesn't make it right.Would somebody please explain to me why 37’s are so bad on a tj? My buddy is running them on his and it a) doesnt look bad b) isnt anymore tippy or unstable c) doesnt break everything
Because there's not an axle the factory ever installed into a TJ that is strong enough for 37's except if that TJ never does anything tougher than mall crawling.Would somebody please explain to me why 37’s are so bad on a tj?
Based off what you are asking, you are looking to put 35’s on for pure looks, am I right?I've never cared about my scrub radius because I've never heard of it until 30 minutes ago reading that post of yours I quoted from. That's why I was asking about 35s on the stock axles, which I though could be done without issue. Are you saying that there's no way to properly put 35s on stock axles?
I'm no expert but here is a short video that explains a little about Scrub Radius.
It has to do with expectations and reality thereof. As you lift and put bigger tires on, the challenge is to maintain or improve stock handling and driving characteristics. The reason that Currie likes to see a wider axle is so that a good scrub radius is maintained to slow down tire scrub, ease the burden on steering components, and maintain good steering response.I've never cared about my scrub radius because I've never heard of it until 30 minutes ago reading that post of yours I quoted from. That's why I was asking about 35s on the stock axles, which I though could be done without issue. Are you saying that there's no way to properly put 35s on stock axles?
As you move the tires outward without making the axle wider, you are increasing the amount they roll to turn instead of pivoting on the contact patch.
At the end of the day it boils down to what we can get by with and not adversely affect what we need the rig to do. Since is it common to ignore most of that, we see a lot of comments to the effect, "it's a Jeep, it is supposed to ride, handle and drive like shit".
If you keep the tires tucked in as tight as the rubbing will allow and maybe a bit less, that is getting things on the right track but it will never be ideal. Whether you notice it will depend on how the rest of your rig is built.
Accept the compromise, build around it and keep the backspacing around 3.75-4"So understanding that it's impossible to have the ideal setup on stock axles, how would you put 35s on an LJ Rubicon's D44s?
