You've done more wheeling in the last 2 months than since I've seen you do since I joined this forum
Clearly, AZ was a good move and selling the silver one was the right call.
The silver one would not have lasted long out hereYou've done more wheeling in the last 2 months than since I've seen you do since I joined this forum
Ame The silver one would not have lasted long out herethere’s too much fun to be had in the rocks
How often are you guys greasing the zerks and Johnny Joints? Wondering if this is something I should be doing after every wheeling trip or what.
Zerks I just do once per year or whenever I remember honestly since I don't drive the Jeep that much. Every oil change would be fine.
The zerks on the JJ's aren't of very much use. They don't really do anything. You have to take the joint apart to grease them which is pretty simple if you get the tools from Currie. I found that my JJ's with the stock Currie grease were a little dry after about 18 months and maybe 8k miles or so.
This is the tool you are referring to I assume?
https://savvyoffroad.com/product/ce-9110t/
Have you used it before? Can it be used pretty easily while the joints are still attached to the arm under the vehicle?
@ToddK, do you know when the joints were last looked at and if they were packed with grease.
I knew the zerk fittings on them were pretty much useless.
Yes, but what about the front track bar, what size joint is that?
My Currie front TB is a 2.5"
I believe Blaine recommends Red N Tacky for JJ grease. It is what I used and I'm hoping it lasts longer than the stock Currie grease.
I think for the JJs he prefers the redline CV-2, but I don’t know the major differences to suggest it matters more than knowing Currie wants a moly grease and redline includes that in the description!
https://www.amazon.com/dp/B0053O9FQS/?tag=wranglerorg-20
The uppers in the front were a bitch to reach without taking the control arms off so I would start with those because I couldn’t grease them as often/easily. All the others would usually take one squeeze of grease every few thousand miles. That grease gun I put in the Jeep for you before it got shipped has the recommended Redline CV-2 in itThis is the tool you are referring to I assume?
