Now I really have no excuse not to do the PSC install. The 97-02 steering shaft gets here Friday
Where’d you order from?Now I really have no excuse not to do the PSC install. The 97-02 steering shaft gets here Friday
Ouch, I’ll evaluate if I need it as I get into mine.https://www.amazon.com/gp/product/B01C0Y6LZG/?tag=wranglerorg-20
Wasn't cheap, but it's brand new, and it makes for an easier install as oppose to modifying your 03-06 steering shaft.
Would you paint match yours, like your fenders?It turned out great. Head up to nor-cal and put one on mine now.
@Chris have you noticed if you are making contact with your front fenders at all while offroad?
With the use of the genright inners, does this create more room behind the front tires?To my knowledge, no, I am not making contact. @starkey480 would have pointed it out I'm sure during our wheeling trips. Also, from watching all the videos that have been taken when we are wheeling, I don't see any issues with the tires contacting the fenders.
I also have to assume that Vegas 4x4 (who built the rig) knew what they were doing when they set it up. I'll obviously go through and cycle the suspension in-depth when I install the outboard shocks.
Compared to stock, yes.With the use of the genright inners, does this create more room behind the front tires?
Assuming it comes in aluminum, I would first place it on the hood and see how it contrast with the rest of the jeep. If it didn't tie in with the raw aluminum skid / control arms then I would paint match it.Would you paint match yours, like your fenders?
I'd rather highline and at that point I'd be looking hard at the GR composite hood.
I'll take out the grinder now and start the cuts for the frame strech right now.So in other words, you'll be going to 37s soon?
How do they remount the battery?Yes, having compared it to my stock TJ Rubicon, there is more room.
I have many years of wheeling before my abilities get close to the jeeps current capability.
I can't drive a rock buggy on the road in CAThe battery isn't affected, it remains in the factory location.
And at that point I hope your sanity and common sense have you building a rock buggy instead
A tube chassis TJ though
I know for a fact genright and poison spyder do not properly relocate the battery. They rely on the firewall only to support the battery. Which leads to....How do they remount the battery?
