Why not MCE front fenders, much cheaper and may hold you over for awhile until you go full highline with the other associated mods
I'm still thinking out loud about fenders. What's the point of going with a GR Aluminum that's not HiLine? I mean, it's $1300. Besides the work involved, why not just go with the HiLine? If I do HiLine, I can run 35's, but what else would I have to change. Am I going to want more uptravel? longer shocks? Modify the upper spring perches?
Brakes. Steering linkages. Axles, if you haven't already.
All the more reason to outboard!
No doubt. I'd rather buy once, cry once and go full outboard than pay $2K for a 6pak of shocks. I usually spend $7 on a 6pak around these parts.
Reactions: Alex01
No doubt. I'd rather buy once, cry once than pay $2K for a 6pak. I usually spend $7 on a 6pak around these parts!
Especially if you consider an outboard is less than 2k, assuming you do the labor...
Reactions: JMT and jjvw
  • Wow
Reactions: Alex01
I still have some things I could do to the 33 build
1) Savvy Oil and Transmission Skid
2) Savvy Gas Tank Skid (I did the 1" OEM Gas Tank Skid Lift, but meh, just get the Savvy)
3) Another 1/4" of bump up front
4) Replace the front fenders
Everything else is dialed in. Shock travel is 50/50. No vibes. It's a great rig. I love it off-road and on.
Front axles are done, front brake pads are done, but no BBK. Steering linkages no done.
Reactions: Alex01
Because they might blow off on the highway. 🤣
Ha, I missed that story... I haven’t had that issue yet. Good news If you bump them into things they’re flexible. Install of those may temporarily scratch the itch of cutting sheet metal too
Reactions: DrDmoney
Is there a percentage of alcohol in the beer before it gets taxed, like in Utah?
No, they classify it as spirits. Beer is not classified as a spirit, so ABV in beer doesn’t matter. I’ve seen up to 9.9%. Spirits are taxed 20.5% plus a sales tax by a liquor store and 13.7% in an establishment
I’ve really thought about it and that might be a viable solution. I’m not in love with the look, but flat is Jeep original, and there is flex, so that might work!
Reactions: DrDmoney
Reactions: Alex01
You really only need fronts, and for $218 it’s a cheaper solution to a problem...cutting up the OEM fenders might be the push you need to go 35’s 🤣
https://jeepsarelife.com/mce-fender...5-f-2-front-flat-fender-flares-textured-black
I’m good with cutting up the OEM fenders. I think I might go this route. It was on the table two years ago, but they were like $550 then! I was like, shit no way, just not worth it. But the flex always attracted me, not transferring energy to the body is good, though those who have aluminum don’t tend to report body damage through hitting them.
Putting in an order. Thinking about just going straight to 35’s without changing setup now, checking bump, making any smal adjustments needed and forging ahead to new realms.
Thanks, good thoughts!
