Picking up where I left off
I wanted a RubiCrawler but with the 4.1 it doesn’t make sense. Based on the wheeling I’ve been doing I can’t think of a single situation where I would need to crawl any slower than I already can.
So, when is the Rubicrawler getting ordered? Don't give me that you don't "need" it either. I know you don't "need" it. Just knowing that dead space exists between your transmission and T-case will eat at you and you wont be able to sleep. Thinking about how that extra planetary could help you out.......
Have you been drinking today? I’ve been monitoring your forum activity today and it’s indicative of someone whose drunk 🥴
It’s for crawling faster
That never stopped anyone 😉🤣
I don't know how many posts I've made today? I can tell you my give a shit is low here today. And I took Thursday and Friday off. Then may give notice next week, so that could be a factor.
Plus I thought only the "Cool" kids had a coma in their post counts??? I'm trying.
This is true, but I can’t imagine needing to crawl faster out here.
That’s what it is! Getting ready to start a new career so you’re letting your freedom flag fly 🤣
You have to try to beat my post count now 😉
Reactions: Cross-Threaded-06TJ
A post count only 60 times higher than mine? Challenge accepted.
Here is my online sobriety test in your thread... This new Job has a mandatory life insurance policy. I will list you as the sole beneficiary of my Rubicrawler if I'm killed at work.
The Jeep will get taken to a shop the Crawler Removed and sent to you. And my Jeep will be auctioned for charity. Granted I'm dead.
That's not a drunk man's post. And you will have a Rubicrawler Free! Well, the price of my life but hey. ;)
So I’ll have your RubiCrawler and Tox’s transmission? Man, now I need to get something from @Alex01
Progress:
Somebody is going all out! Separated locker switches and transmission temperature gauge ....nice adds. Pics of the trans cooler mounting?
Reactions: starkey480
Progress looks good! I need to add my temp gauge that’s been sitting on the shelf in the garage. This is also motivating me to raise my body mounts. They have taken a few hits.
The Setrab cooler is mounted right below the PSC cooler:
Those switches are awesome! Link?
Are you still running factory air lockers?
For now I am still running the factory air lockers. Eventually I'll replace the front with a Detroit full case and the rear with an ARB or Eaton. I wanted them on separate switches though since I have grown to loath the factory Rubicon locker functionality.
The way Blaine set those switches up is so that the light on the switch illuminates when power is sent to locker pump. The indicator light above lights up when locker is locked.
As for the switches, I got them here:
https://www.ebay.com/itm/Fits-Jeep-...d=link&campid=5337789113&toolid=20001&mkevt=1
Hey now. I get my parts from you. Let's keep it that way.
I'll take the bead locks, half-doors, and that new fancy air gauge you have.
Are you going to be running a remote tank to prepare for an Arb in the future?
Reactions: D M, Irun and Chris
At some point I'll probably add a remote tank, yes.
I'm going to live with it the way it is for now. If at some point I have a reason to re-gear to 5.38, that's when I'll do the lockers. If I get it back from Blaine and it's mostly vibration free the way it is now, I may just never re-gear to 5.38 simply out of fear that the 5.38 gears will invoke the crazy vibrations I had on my last one.
I've priced out a hub kit and that rabbit hole would be upwards of 6k pretty easily purely based off the fact I would need new wheels and these wheels ain't cheap!
Reactions: Alex01
You can get the small hub setup. I'm fairly confident @Midnight LJR has the stock bolt pattern. He had to get something like 4.5 backspacing though to account for the extra inch the hubs added to the wheels.
Reactions: Midnight LJR
Yep, and my issue is that my wheels are currently 3.75" backspacing. So that leaves me having to order new wheels which would be around $3000. I could sell my wheels and offset the cost, but I'm still left having to swap tires (not much fun on beadlock wheels).
Then there is the cost of the hub kit and probably some other stuff I am leaving out.
It may end up that I go down this path eventually anyways. If I could find someone to pay top dollar for my wheels I might be tempted to do it. These wheels are $600 a piece, so $3000 for a set. Maybe if someone paid me $2500 or so I might do it.
Reactions: Alex01
What's the reason you'll need new wheels again? Hub won't fit through the center hole? Or too wide?
