That's with my original write-up that includes the .5" BLAnd it looks great! Thanks!
Got a pic?I have a question for you guys that have done this lift. I’m in the process of installing 2” coils and the rancho’s (no body lift yet). I’m cycling the front suspension to see what bump stops I need. I’ve got the springs out, but the shocks in, the track bar connected, but the sway bar disco’ed. 30.5” tires. Measuring cup-to-spring base. At full shock compression, I’m measuring that I need 2-3/8” of bump stop. (Just call it 2.5”) Based on what I’ve read, that seems like a lot of bump stop. Especially for the 30” tires I have. Am I doing something wrong here? How much bump stop did you guys have to use?
I’m going to answer my own question here, and share how absent minded I am. Maybe a learning experience for someone else. When you are disassembling and may notice your bump stop cup is rusty and could use some fresh paint, it’s very easy to do. Just be sure you put the bump stop cup back on before you take measurements.Got a pic?
Are you measuring cup edge or center of the cup?
hahaha. That explains the large bump stop requirement.I’m going to answer my own question here, and share how absent minded I am. Maybe a learning experience for someone else. When you are disassembling and may notice your bump stop cup is rusty and could use some fresh paint, it’s very easy to do. Just be sure you put the bump stop cup back on before you take measurements.View attachment 245445
I must admit I'm feeling a little bit confused with the post. Do you have any picture? Probably this would help.I have a question for you guys that have done this lift. I’m in the process of installing 2” coils and the rancho’s (no body lift yet). I’m cycling the front suspension to see what bump stops I need. I’ve got the springs out, but the shocks in, the track bar connected, but the sway bar disco’ed. 30.5” tires. Measuring cup-to-spring base. At full shock compression, I’m measuring that I need 2-3/8” of bump stop. (Just call it 2.5”) Based on what I’ve read, that seems like a lot of bump stop. Especially for the 30” tires I have. Am I doing something wrong here? How much bump stop did you guys have to use?
Read is post of a few minutes later where he explained his mistake.I must admit I'm feeling a little bit confused with the post. Do you have any picture? Probably this would help.
You'll be fine adding the spacers.** first post here
Thanks for this write up. I ended up going with most of these items other than the body lift. I also added adj front and rear track bars.
Quick question - I’ve let it settle for about 3 weeks now and there’s still a pretty large amount of rake with the 2” procomp springs without the spacers. I’m showing the rear as being 1.8” higher than the front. I’d like to throw the .75 spacers in to level it out but I’m afraid it might develop vibes and I’m happy with how it drives right now.
Would adding the .75 spacer to the front affect the driveline vibes?
Very nice. How hard was the relocation bracket? Im getting the same setup except was thinking bout just going with an adjustable track bar instead.Thank you so much for this thread. Just wanted to share the results. This is my ‘97 SE after doing the 2” procomp, rancho 5k(0”-2”), with .75 spacers up front and the OME rear bracket. Full disclaimer, this is only minutes after setting the rear end down, so I think she will settle a little. The front was done a week or two ago.
All done alone in a 9’ wide garage with basic tools, so it CAN be done. I’ve officially caught the bug. More to come.View attachment 248647
That method works great with a JKS barVery nice. How hard was the relocation bracket? Im getting the same setup except was thinking bout just going with an adjustable track bar instead.
The hardest part for me was the whole finger fumbling thing of trying to get nuts into a very tight space (insert joke here). Not impossible, but frustrating at best. I would have probably spent the extra pennies on an adjustable bar, if that eliminates the need for the bracket (I don’t know if it does). But, I did it on the ground and not on a lift, so maybe that is a factor. Either way, I got it done, but was the most frustrating thing of this whole lift process. I can’t give a better recommendation for a step drill bit than in this application.Very nice. How hard was the relocation bracket? Im getting the same setup except was thinking bout just going with an adjustable track bar instead.
I was setting my bump stops and realized I forgot to put the jounce cup back on......out comes the spring again. All bolted up but waiting on my new jounce bumpers to arrive on Weds. With jounce in hand I found it impossible to squeeze the bumper through the installed springs...out comes the springs again.
It took me most of the day....I was setting my bump stops and realized I forgot to put the jounce cup back on......out comes the spring again. All bolted up but waiting on my new jounce bumpers to arrive on Weds. With jounce in hand I found it impossible to squeeze the bumper through the installed springs...out comes the springs again. By my 3rd removal I was getting pretty quick at it!
Hopefully this thread serves as a resource to others. You're much better off piecing your own lift together as oppose to buying a "kit" in most cases.
- Rancho RS5000X Shocks 0-2" (2 Front) — RS55128
- Rancho RS5000X Shocks 0-2" (2 Rear) — RS55240
- Pro Comp 2" Springs (Front) — EXP55297
- Pro Comp 2" Springs (Rear) — EXP55298
- OME Rear Track Bar Reloaction Bracket — ARB FKWTJ02
- Rokmen 1/2" Aluminum Body Lift
- Daystar.75" Spacers — KJ09108BK (note: only used above front springs for leveling, if you don't care about being level, you don't need these)
If you can change brakes, installing a lift is pretty darn easy, especially this height. It would make it easier if you had someone to supervise you and help out who knew what they were doing. It’s not inherently difficult, but it’s nice to have the eyes of somebody who has done it before just to assist.Thanks, @Chris and @CodaMan!
As the proud new of a 2000 TJ Sport 4.0 (w/Dana 44 rear end), this is exactly what I needed.
In fact, I have ordered exactly this list of parts this morning with the exception of the Rokmen ½" BL kit. I couldn't find it in stock, so I ordered a TeraFlex 1" aluminum BL kit.
I also order a set of 5 Pro Comp 97 Series Rock Crawler with new 32x11.50x15 BFG Mud-Terrain T/A KM3 tires mounted and balanced.
Everything should be here by 6/1/2021.
Now, I have a question. I'm not a mechanic. The most "advanced" thing I've done is changing brakes, drums, and/or rotors on several vehicles. Is this a DIY or should I have my mechanic handle all of this for me?
