What year model ?Without reading through 17 pages... Is it possible to to do a TT on a LJR without doing a MML?
No, you have to read the 17 pages. That’s the initiation fee.Without reading through 17 pages... Is it possible to to do a TT on a LJR without doing a MML?
The Savvy MUA says yes.Without reading through 17 pages... Is it possible to to do a TT on a LJR without doing a MML?
That's a good idea. I knew the MML is need on a TJ for the reasons you mentioned, but I figured on a LJ it probably isn't needed. I'm looking at the UCF skid that doesn't require a body lift and retains the factory transmission mount.I don't see why you wouldn't be able to. The MML is used to decrease the rear DS angle and in turn the pinion angle. With the increased length of the LJ driveshaft, you may be fine. If it was me I'd order a JKS MML off amazon, install the tummy tuck, if were no vibrations return the mml. That way you at least have it on hand if you need it.
Amazon currently has an open box mml for a decent amount off. https://www.amazon.com/dp/B005TTZF52/?tag=wranglerorg-20
To be honest, I am trying to lessen the angle on the front driveshaft output yoke on the tcase. My thought process could be wrong but just doing a TT only would increase my rear output angle (which doesn't matter since I have a LJ) but would decrease the front angle. If I would also install a MML it would be no different than where I'm at already.why would you though? I found the MML no more difficult to install (the second time I did one) than removing the radiator shroud and putting new holes in it to line up with the fan.
I guess if you've already done the work to move the shroud...
there's some trigonometry involved there. It'll move the angle of your front output yoke closer to horizontal which by itself would decrease the operating angle of the cardan joint, but raising it 2+" will also increase the angle of your driveshaft which will INcrease the operating angle of the cardan joint. So you'll be making 2 opposing adjustments and I don't immediately know which will win out. But either way, you are correct that a MML would definitely NOT move you in the direction you're wanting to go.To be honest, I am trying to lessen the angle on the front driveshaft output yoke on the tcase. My thought process could be wrong but just doing a TT only would increase my rear output angle (which doesn't matter since I have a LJ) but would decrease the front angle. If I would also install a MML it would be no different than where I'm at already.
I'd didn't think about it raising the front as well, so thanks for pointing that out. Goal for me is try and get the front output yoke close to horizontal. I'll have to check and see how much the UCF (No body lift version) actually lifts everything.there's some trigonometry involved there. It'll move the angle of your front output yoke closer to horizontal which by itself would decrease the operating angle of the cardan joint, but raising it 2+" will also increase the angle of your driveshaft which will INcrease the operating angle of the cardan joint. So you'll be making 2 opposing adjustments and I don't immediately know which will win out. But either way, you are correct that a MML would definitely NOT move you in the direction you're wanting to go.
UCF got back to me and said the Skid that doesn't require a body lift will lift the transfer case by 1.25".there's some trigonometry involved there. It'll move the angle of your front output yoke closer to horizontal which by itself would decrease the operating angle of the cardan joint, but raising it 2+" will also increase the angle of your driveshaft which will INcrease the operating angle of the cardan joint. So you'll be making 2 opposing adjustments and I don't immediately know which will win out. But either way, you are correct that a MML would definitely NOT move you in the direction you're wanting to go.
Mine is at 4" of spring with the Savvy skid. Mine is a Rubicon, which might be the worst setup for the driveshaft. So far, so good after about 4 years. This isn't an uncommon combination.I read a lot of the thread but not every page, so apologies if this has been answered already. Is there a maximum suspension lift anybody has found in combination with a TT? I ask because I have Currie 3" springs that I suspect are netting me closer to 4" in the rear, and a Savvy TT which is pretty freakin' flat. My drive shaft angle at the double carden is pretty steep.
YOu could probably mock up a close approximation to the pinion and driveshaft angle with your AA SYE.Thanks guys, that makes me feel a little better. No vibes, just steep angles and a very hot double carden joint. I will add that I'm running the AA SYE, not the super short, and I have an 8.8 which is not only low pinion, but also offset more than factory all of which add to the angle. Does anybody else's double carden joint get pretty hot after driving?
I hope you have room for a 1.5" MML. You may have to modify the fan shroud just below the radiator hose to clear. Keep us posted. I don't recall anyone adding a 1.5" MML on the forum. Did you talk to Tim at Brown Dog about it? Curious.Got the angled track bar mount. I'm using the Artec truss/mount kit for the 8.8. I do wish in retrospect I would have held out for a Dana 44 but I couldn't source one at the time. For the temp, I'll check it with a temp gun sometime soon, but too hot to touch for more than a second or so. Much hotter than the shaft itself.
But just hearing you guys have that much lift with a TT makes me feel better. I was tossing around the idea of shorter springs to get my angles down, but I'll hunt other things first. Just ordered a 1.5" MML from BrownDog to help straighten it out a little more (already running a 1' MML).
The 1.5" mml could cause interferences at the trans tunnel.Got the angled track bar mount. I'm using the Artec truss/mount kit for the 8.8. I do wish in retrospect I would have held out for a Dana 44 but I couldn't source one at the time. For the temp, I'll check it with a temp gun sometime soon, but too hot to touch for more than a second or so. Much hotter than the shaft itself.
