Tworley build
That’s the only spot my Jeep had rust when I got it as well. I’ve replace the middle torque box mount on both sides of mine
Interesting--yours was a local find too wasn't it? In AZ?
i think it's just a moisture trap no matter where you live.
the way they pushed the dimple seems like it kinda bulges the channel oddly and created small bowled areas around them allowing water to puddle there.
Spring Creek this morning!
You’re having a rough year. Can’t get out, then get out and mess stuff up. Then there’s the pile of other stuff to fix. I can identify. Hang in there!
Thanks! It happens. I knew going into this year that it would be tough to get out. Sometimes there are more important things to do. The good news--all of it is fixable with a little time and money 😅
The driveshaft is good enough to use on the trail. So I'll be able to get out for a couple more runs!
