Interesting--yours was a local find too wasn't it? In AZ?That’s the only spot my Jeep had rust when I got it as well. I’ve replace the middle torque box mount on both sides of mine
Bent enough to cause heavy vibes. Also spline playDIY barber pole? just the paint or did ya bend it?
You’re having a rough year. Can’t get out, then get out and mess stuff up. Then there’s the pile of other stuff to fix. I can identify. Hang in there!Bent enough to cause heavy vibes. Also spline play
Thanks! It happens. I knew going into this year that it would be tough to get out. Sometimes there are more important things to do. The good news--all of it is fixable with a little time and moneyYou’re having a rough year. Can’t get out, then get out and mess stuff up. Then there’s the pile of other stuff to fix. I can identify. Hang in there!
Almost there
You probably won’t find any two rigs in our group that have a straight tie rod!
mine is bent again. just not as bad.You probably won’t find any two rigs in our group that have a straight tie rod!
450. Never used offroad. No lowballs.. I know what I got.
Only bent 7-8 times!450. Never used offroad. No lowballs.. I know what I got.
I guess better to bend than destroy the knuckles with the savvy aluminum bar as blaine warns. But if one person was to test out the savvy bar @tworley is the guy.Only bent 7-8 times!
