Yeah they ended up purchasing some of the old yard stock, the lions share went to jeeps unlimited in colorado.Must be an offshoot of the old Olympic 4x4?
Yeah it’s called All About Auto Wrecking, in Snohomish.What is the name of that yard and where are they located?
Is the rake even on both sides of the rear?Okay quick question: I’ve had some rake since i installed the OME lift, but didn’t do anything about it. Today i measured how much it raked and it seemed to be about 2” lower in the front. What’s the best plan to level this out? Should i put 2” spacers in the front or get some longer front springs?
The rake is even on both sides. I also thought that 2” spacers was a lot, though the rear is usually pretty light compared to the front. Unless i’m going wheeling or camping. Thanks for the ideas!Is the rake even on both sides of the rear?
How light is it in the rear?
2" spacers is a lot. Mine has a tiny rake but as soon as I put stuff in it (camping, etc.) it levels out. I'd pick up some OME 10mm trim spacers for the front and try those first before jumping straight to 2" spacers. If the lift is new there might be some settling that still needs to happen.
Just throwing out ideas
Thank you! Surprisingly i've found quite a few TJ rubicon moabs in my area. Mostly around 300$, but i picked up 5 of these for 150$, which i thought was a pretty good deal.You have a sweet rig man! I tried to find some Moab wheels but didn’t have any luck. I just ended up going with JK wheels and adapters. Hopefully one day I will find some.
That’s a smokin deal! I paid 400 for my set.Thank you! Surprisingly i've found quite a few TJ rubicon moabs in my area. Mostly around 300$, but i picked up 5 of these for 150$, which i thought was a pretty good deal.
What the heck kind of bubble lens did you take this picture with??! Looks like the door is busting out of the frame and the tires are WAY to big for the lift...Past few days i got the hardtop and doors back on for winter. The hardtop was pretty faded so some penetrol and it cleaned up pretty well!
View attachment 279741View attachment 279742
View attachment 279739View attachment 279740
Haha i was wondering if someone would notice… I was testing out the new wide angle lens on my phone. The door was open in the pic, and i was low down to take the pictures so the tires look big with the wide angle. Though they are too big either way, just waiting on a body liftWhat the heck kind of bubble lens did you take this picture with??! Looks like the door is busting out of the frame and the tires are WAY to big for the lift...
Haha already on itI would get a body lift from Savvy.
Too soon ?
If only i didn’t buy that bumper and saved up for a savvy aluminum, but live and learn
That’s a beast. You tow?I have bumper I could be talked out of ....
