You have mine to do first!You know what it means. Upgrade time!
Or come down to CO and we will nail it out in a day
Ive been wanting to get one too but have the same problem. Hopefully that changes very soon...That’s a big entry fee. My wife might shirk right now. I am. My neighbor has a couple of welders I could use, but they don’t have the auto feed feature. I’d have to practice at his place. My biggest problem is where to put a 211. My garage is tiny and there’s no place right now.![]()
I have this welder and it does a pretty good job, the only trouble I had was with the crappy regulator but that was an easy $50 fix. It has done everything I have asked it to do.So you're not gunna need to come visit the Wildman Gob Fab shop now? Gunna do your own welding and?
I KNOW it isn't a Miller but for half that price you can get this from Harbor Freight.
https://www.harborfreight.com/MIG-1...olt-Input-64805.html?cid=itcnonmember_oct2021
If you're a club member it's On Sale right now for $520. But the extended warranty and you'll be good for a while as you learn. Then once you've learned to weld better then move up to a brand name machine.
Of course look at me where I bought a Lincoln cause they were suppose to be good machines and I'd had one already. Now it's broken and I won't have it for a month or longer. I've thought about getting this unit to hold me over until I get mine back. Other than HEAVY welding a 170 Amp unit will work.
Which hood did you end up going with?When I was looking for a welder, I tried used. Couldn't find anything reasonable. I ended up calling the local supply house that does the most volume. They had just gotten some Lincoln's 201MP's back from their program with the local community college. Call it a Demo Welder. Full warranty and all that, but about 20% off the retail price. I had them set me up with a tank, hood, gloves, etc and I think after tax I walked out of there spending just over 1800 dollars. I've since upgraded the hood...looking back, I wish I would have gotten a good hoof right off the bat. I spent a lot of frustrating hours over crappy beads because I simply couldn't see. The hood made a HUGE difference. I'm still a crappy welder, but at least I can see the crappy beads as I'm putting them down, instead of going blind and praying it will work!
A sellstrom. Something I found at MSC. Price has come down too, since I bought. I think Amazon has them tooWhich hood did you end up going with?
My TJ is buried under rugs, chairs, boxes and a whole bunch of other stuff. I couldnt pull it out of the garage even if I wanted to
And you want to get a welder in there?! I feel your pain.My TJ is buried under rugs, chairs, boxes and a whole bunch of other stuff. I couldnt pull it out of the garage even if I wanted to![]()
We're in the middle of home shopping now. Looking at homes with oversized two car garages (three would be ideal) and I definitely plan on having 220 installed.And you want to get a welder in there?! I feel your pain.![]()
Make sure you have room for an outbuilding too! I have a 20 x 20 garage (which is really only a stall and a half to anyone but a realtor) AND my 24 x 30 shop. Only an 85 x 150 town lot!We're in the middle of home shopping now. Looking at homes with oversized two car garages (three would be ideal) and I definitely plan on having 220 installed.
My current garage is only 10x27. But with a TJ, motorcyle, work bench, deep freezer and winter/summer gear, you can barely move around in there. Our electrical panel is maxed too, no room for any additional breakers.
I don’t want to muddy JMTs build to much but tandem breakers can be a big help in a full panel situation. Some frown on them I only use them if absolutely needed.Our electrical panel is maxed too, no room for any additional breakers.
The body mount ears were totally bent in pinching the rubber body mount. I couldn’t pry them away. I had to loosen 5 body mounts on that side to get enough space to force it out. Then I fixed and cleaned it all up, painted. Back in business till next time.
I’ve looked at the UNAPPROVED swag Bertha mounts before and now I’m wondering if I could weld them on without modifying much of my C bracket for the Savvy MUA. They look like they weld to the side of the frame only and don’t wrap over the top.Mine looked like that also which is why I did the raised body mounts. I know the SWAG isn't the APPROVED mount but I like them and he's a local company. And they are truely beef.
I’ve looked at the UNAPPROVED swag Bertha mounts before and now I’m wondering if I could weld them on without modifying my C bracket for the Savvy MUA.
Can you come over and do all of mine pleaseThe body mount ears were totally bent in pinching the rubber body mount. I couldn’t pry them away. I had to loosen 5 body mounts on that side to get enough space to force it out. Then I fixed and cleaned it all up, painted. Back in business till next time.
