OK so moving to a milder sway up front (making front and rear closer to equal rates) off road is more to balance the suspension front to back as a system instead of on road where it is more of a function to keep stronger roll control around corners.
Right on, thanks for helping me understand it better.
I'll make you a hell of a deal on an aluminum AntiRock
I have the Terraflex equivalent to the Swayloc and although it is generally quiet it can make a racket if not periodically lubricated. The inner shaft needs to be removed, lubricated and re-installed. Otherwise the inner and the outer shafts bind up and start making noise. I suspect the Swayloc might do the same because they are similar construction.
The latch mechanism on the swayloc makes a hell of a racket when you drive over slightly rough pavement. Most noticeable at slow speeds. I think it’s extremely annoying but for me, I enjoy the other factors of the swayloc so I will not replace it.
Check to be sure the rattle you hear isn't the heim joints. I've had 2 fail on me in a short amount of time.
If that liner you see working its way out escapes completely, the heim rattles like the Dickens.
I did not use those POS heims. Noise is gone when unlocked.
Is it the little flipper lever?
Wouldn’t happen to have a link to those?The provided heims have been the only noise I have identified coming from the SL. They survived about a year before the liner squeezed out, but I think I also damaged them with too much shock travel. The FK rod ends I replaced them with are still tight three years later.
