It's always good to have a spare PCM. I've got a spare WranglerFix PCM sitting on my shelf as well.
Yeah, but you're a mod collector.
The only part not a KT to be updated is the software. You can adjust tires, gears and speedometer as normal.On the site it says that it is not tunable. Is that still true? This would not allow tire size changes and my Banks system would be rendered useless.
Could that be done by you when we order? (Tires, gears, speedo)The only part not a KT to be updated is the software. You can adjust tires, gears and speedometer as normal.
I'm sorry, but I'm not sure I understand. I can or cannot use a tuner on your PCM?The only part not a KT to be updated is the software. You can adjust tires, gears and speedometer as normal.
It looks like spellcheck got me. You can adjust tires, gears and speedometer with a tuner. Software cannot be updated and no turbos or chips.I'm sorry, but I'm not sure I understand. I can or cannot use a tuner on your PCM?
Thanks for the reply. Well, too bad. Glad you been able to help others though. Luckily only happens on mine when cold and only once. I should feel lucky.It comes with stock programming. I don't
Yes, sir. I see that Matt’s video dropped about an hour ago on YouTube.i will never spend 5 cents on AdWords.@Wranglerfix. Mark, I see you got a shout out from Bleeping Jeep with his using your PCM on his FC build.
Did you intend to include a link?Hey guys, I made a quick you tubes video on my @Wranglerfix PCM that I installed on my 2005 Wrangler Unlimited Rubicon.
Check it out and let me know if I missed anything, or if the video needs to be redone. I'm by no means a professional you tube vlogger, but maybe this video can help someone who might be having PCM problems.
I totally did not!Did you intend to include a link?
No worries! I hope the video is OK, I just hit record on the phone and rambled on a little bit. Lol@GorillaBiscuit Thank you for your testimonial, sir. It is greatly appreciated.
Is there more to this story? Don’t you have an LS?Everyone has there good and bad experiences. I would never, never recommend Wranglerfix. I would recommend SOS Diagnostics.
