Anyone ever use mega short NP231 conversion?
Anyone every use this..Whats your opinion, looks like a great idea....
Rugged Ridge NP231 Mega Short Slip Yoke Eliminator (SYE) Kit with Speed Sensor
https://www.morris4x4center.com/slip-yoke-mega-short-eliminator-kit-w-speed-sensor-18676-72.html
No experience with it. I installed this on a buddies TJ and I'll be putting this on mine as well.
http://www.jbconversions.com/products/sye/np231j_short_sye.php
Seems to be the go to for anyone considering a TT, if a TT is not in your future then Advanced Adapters makes a solid unit.
https://www.morris4x4center.com/adv...EdLHxe95g55w-9A7qxxoC3q8QAvD_BwE&gclsrc=aw.ds
Word of warning, if you go with a Super short SYE and have a gear driven speedo then you will need something like a healtech to have an accurate speedo:
http://www.bluemonkeymotorsports.com/products_ht.html
I want to say this is the one @Kevin E has on his. If it's not the exact same one, I know he has a super short one.
What’s the difference between the standard sye and a super shorty sye?
I know one is shorter but what’s the advantage or disadvantage of the two types?
Having as long of a rear driveshaft as possible is always a good thing. Especially if you are going to tackle mods like a tummy tuck and build in long travel rear shocks. A few of the "advanced" mods are limited by how much angle the drive shaft allows before binding.
Reactions: JeepNWilly
I only have a 2” lift, I might go to a 3 in the future.
Would I still benefit getting a shorty sye?
You would be fine without it but you will still benefit with a supershort or megashort sye. The only downside of a supershort or megashort sye will be the speedo calibration as they do not use the speedo gears. you will need an electric speed calibration to fix it.
I have a 06 TJ. I believe my speedo is electronic?
