I recently purchased this '05 wrangler sport. I knew before I bought it, it had death wobble,experienced it on test drive. I first replaced the steering dampened,because the one on there was totally shot and leaking oil. Then I searched out the culprit of the death wobble. Everything seemed tight except both hub bearings had excessive play in them. Replaced both hub bearings. No more death wobble. Now to the real problem. Bump steer! I did not do any of the lift and have no idea of the make of the parts. Front springs are 16" and rears are 12". There is a 1 1/2 square tube on top of the frame at the body mounts. Tires are 33 x 12.5. They were way over inflated to 42 psi. Knocked them down to 30, thinking on going down to 26. The geometry is an absolute train wreck. Whoever done this had no clue. Not only are the drag link and trac bar not parallel, they actually cross! I am looking for advice on how to fix this. What is out there in way of different bracket for the passenger side of the drag link? The pitman arm is factory, not dropped. The trac bar is not adjustable. I'm thinking I will most likely need an adjustable one though. Stabilizer arms are adjustable. Upper and lower control arms seem to be stock. Caster seems to be about 6 degrees negative. Toe is about 1/16" inward. I have attached pictures and sketch. Sketch is looking from front and dimensions are from level floor. Any help would be appreciated.
