I received my rear control arms yesterday. No pictures yet, but the lowers are very beafy. I didn't expect such a heavy arm. The uppers are a little smaller, but still plenty strong. Both appear to be well built. So my first surprise was how heavy they are. My second surprise was that the bushing was pressed in. On the website they show bushings with snap rings, so I was expecting a snap ring to hold it in, but they are pressed in on both ends.
As far as the D2 bushing itself, it looks indistinguishable from this picture of the Synergy DDB. Looking at it from the outside casing to the inside sleeve. I can see it has the steel casing where its pressed into the housing in the arm. It appears to be the same black 'rubber' outside durometer with the steel reinforcement ring and then the black harder inner durometer followed by the inside sleeve where the bolt goes through. All appear to be the same as in this picture.
EDIT: For comparison here is a picture from Rancho. This is how mine look.
NOTE: Looking at these two pictures the bolt sleeve in the DDB appears to have a slightly beveled corner that is not present on the Rancho D2. But this might be application specific.
Comments about the material: The 'rubber' of the different durometers is kind of interesting. I'm not sure what I was expecting, but I was surprised by the feel of the 'rubber'. Because the inner, softer, durometer is inset, you can't really get a feel for it, but the harder outside durometer, around the bolt sleeve, has a very smooth and clean hard rubber feel to it. I couldn't really describe it at first. Kind of like the sole of a hard shoe, but different. The more I felt it and played with it, it hit me. The material feels very similar to the the 'Crazy Balls' you can get out of kids vending machines at Walmart. Maybe a bit firmer. In fact, if I bounce the control arm on the corner of the bushing, it kind of has that same 'Crazy Ball' bounce to it. I'll admit that the idea of the control arms being cushioned by crazy balls creates a bad visual of a Jeep bouncing down the road, but I think any rubber material, including the stock Clevite, will have a certain amount of bounce to it. So I'm sure the material will function as its intended. No need to worry about bouncy off rocks like a Crazy Ball.
I did not have any experience of the inner sleeve sliding out as an earlier post about the Giiro joints suggested. Everything felt firm and tight. I could not even turn the inner sleeve by hand. So it takes some force to spin the sleeve inside the bushing. More like how the Synergy bushing was described. I might be able to get a better comparison here in the future as I am tentatively planning on using the Synergy JK bushings on the front axle side of the arm.
I will comment that it does take some force to flex the bushing. I stuck a screwdriver into the bolt hole to see how much I could flex it by hand. I got a little flex out of it, but it also bent the shaft on my screwdriver. Fortunately, the bolt hole is bigger than the screwdriver I used. If I can find a rod the same size as the bolt hole I will try another flex test.
All in all, I think the Rancho arms with the D2 bushings will be a solid product. I'll add more info here or create a new post with a review after I get things installed. But that might be awhile since I am still waiting for the front arms which are on back order.
