Hahaha I know it’s some kind of bmw. It’s my housemate’s. I’m not that cool yet
Welcome,you can do this,you can make a tj drive perfectly,we drive ours across the country.what part of Missouri,I am from st.charles.
I am in Springfield. I want to get her all fixed up and drive her to Utah where my parents are. It might cost and arm and a leg but it would be fun![]()
we haven’t had enough warm days in between the cold. All I want to do is give her a good cleaning!! I detailed the dash the other day and she already looks 10 years younger lol
I’m definitely going to do the ZJ conversion here in a couple months. I’m trying to sort out some bad ball joints, my broken tailgate, and why she seems to have trouble starting first. But I definitely need to learn how to do alignments because I’m going to be replacing most of the steering/suspension components.
You need two 3ft metal square tubes, two tape measures and three clamps:
[URL]https://wranglertjforum.com/threads/how-to-align-your-jeep-wrangler-tj.85/[/URL]
For most TJs (all stock TJs?) the camber and caster can't be adjusted.
Andy
Andy
I just had the same starting issue on my Yukon. Hard or no start on the first key up. Second try would always fire up. Ended up being the fuel pump failing and leaking off pressure between running. Could start with a fuel pressure test: off, at key up, and running.
