Welcome to the forum!Nah tbh I was confused about how a 12” would fit without making a complete buggy this is what I was looking for![]()
Good, cause I lied about em being ok, they're all assholes!Nah tbh I was confused about how a 12” would fit without making a complete buggy this is what I was looking for![]()
Glad to see you have some sense lol these guys were going to rip you and apartNah tbh I was confused about how a 12” would fit without making a complete buggy this is what I was looking for![]()
Are you?...
I’m surprised no one has told you do looking into savvy’s mid-arm.
Right now I’m running Johnny Joints all around, 35’s high line, lockers, etc and the only thing holding it back is the wheel base. In Az there are few Ljs on the market and if there are people want like 20k+ which is outrageous in my opinion. If I end up diving in I’ll just swap jk 44s and probably a 5” stretch and call it good until I get the urge to take the front apart relocate everything just to gain a couple more inchesGlad to see you have some sense lol these guys were going to rip you and apart
My Jeep is older than you. Only your GF can answer that question and she will lie to you so she doesn't hurt your feelings.just to gain a couple more inches![]()
If you stretch 12” you will need larger tires.Right now I’m running Johnny Joints all around, 35’s high line, lockers, etc and the only thing holding it back is the wheel base. In Az there are few Ljs on the market and if there are people want like 20k+ which is outrageous in my opinion. If I end up diving in I’ll just swap jk 44s and probably a 5” stretch and call it good until I get the urge to take the front apart relocate everything just to gain a couple more inches![]()
I'll be doing 6" without a back half kit.If you stretch 12” you will need larger tires.
Larger tires=new axles
Even a 5” stretch is going to require some fabrication and welding to do correctly. Remember you can’t simply bolt on longer wheel base correctly. The rear cannot go back with out addressing the gas tank and the frame. So a fuel cell and a back half kit at the minimum will have to be done, even for 5”.
If I went 1” in the rear I would have to address my fuel tank.
In this world, honesty makes you dysfunctional.Dysfunctional but honest. Lol
Perfect.. If I end up diving in I’ll just swap jk 44s
Not with that kit. Lol.I'll be doing 6" without a back half kit.
JJ - Will you need to do a comp cut at that stretch?I'll be doing 6" without a back half kit.
Is all 6” in the rear? Curious what your plans are.JJ - Will you need to do a comp cut at that stretch?
I believe he was referring to an LJ, though even in a TJ you can certainly stretch 5" without a back-half kit. There are also a handful of gas tank options that don't require going to a fuel cell (not saying any of this is smart or bolt-on, just that there are other ways to skin a cat).Even a 5” stretch is going to require some fabrication and welding to do correctly. Remember you can’t simply bolt on longer wheel base correctly. The rear cannot go back with out addressing the gas tank and the frame. So a fuel cell and a back half kit at the minimum will have to be done, even for 5”.
