Thinking about doing a crazy tj stretch, some custom stuff front end, but for the rear I found this kit that says 12” stretch. I want to figure out is this a legit 12” stretch kit? Has anyone every used these brand or this exact kit?
It isn't the dumbest shit you can do. I've seen worse.This is the dumbest shit you could do to your jeep. Notice how it only comes with 2 springs? That’s because they have you move the coil bucket back on the frame and use a stock height coil spring.
It’s an extremely stupid way to spend $3239.It isn't the dumbest shit you can do. I've seen worse.
Could be worse. Could spend $3200 on a $500 hooker………..It’s an extremely stupid way to spend $3239.
Fortunately I’m not yet at the age where I have to pay for that.Could be worse. Could spend $3200 on a $500 hooker………..
No issue there but it isn't the most stupid.It’s an extremely stupid way to spend $3239.
of all that's going on with this kit, that might be the thing I have the least problem with.
My problems start with how they just completely gloss over a lot of details that have to be thoughtfully worked out like it's just a footnote. I wonder how many unsuspecting shoppers end up buying this kit and end up way over their heads.
this is industry wide.My problems start with how they just completely gloss over a lot of details that have to be thoughtfully worked out like it's just a footnote. I wonder how many unsuspecting shoppers end up buying this kit and end up way over their heads.
at this stage there is no "kitting it" , it's all fitting it.Knowing how I want to get just a simple 6" out of the back on mine, I can't see anything in this kit that would help me achieve a full foot in any way I could find acceptable.
It's a 3" stretch on an LJ. Much easier and you can probably use a 2" rear lift spring.How is this accomplished on a TJ platform? No mention of stretching the tub (LJ conversion)?
Do not despair, there's an "Off Road PRO" kit for the later models for a kool $3,639.Why is this limited to 97-02? Is it because of the EVAP system in the rear corner of the later models? Didn't they cover that problem in #11?
The skid plate! I forgot people attach the arms to that. How silly of me.Do not despair, there's an "Off Road PRO" kit for the later models for a kool $3,639.
https://millerrockracing.com/i-7876...-road-pro-03-06-wrangler-tj-rock-krawler.html
