Okay - Just ran into a "challenge" - mine being an '04, I've got that intrusive "lever" blocking me from sliding that SKIM unit cleanly over the ignition switch assembly - suggestions?
Appending this "panic post" with some useful info for the group; to wit: If you have the dreaded ignition switch "lever" as *I* do on my '04, you WILL need to unplug the two plugs and remove the Multifunction Switch in order to slip & clip the SKIM Module in place "from the top". No big deal really - 2 more screws to remove, lift off the switch after unplugging, replace after slipping the SKIM into place. Now it's off to the Stealership to hopefully get this operational!
