I put the windshield, fenders, and hood on. Glass is installed, mirrors, footman loops. Lots of things painted either black or tan. View attachment 627506A huge list of details checked off
Beautiful.
I want to hear your thoughts on the contrasting Red grill. Love it? Hate it?
You've done some amazing design and fabrication work. It keeps getting better and better.![]()
I would try to hook up a tester and see if you can get it to act up while driving it & that might show you where the problem is. Is the coil new?
80 PSI for compression even at your elevation seems low. What is the vacuum doing when driving and it's stumbling?
While you can't throw a scan tool on it and do data logging you can still hook up testing equipment and see what is happening.
I had a CJ5 that would act up once it was warmed up and I was driving it. Turned out to be gunk in the fuel tank.
After going over EVERYTHING again: Ignition, timing, fuel, coil, I even pulled the timing cover off to make sure I didn't get the chain off one tooth (new chain). I pulled the head to measure how much the valves raise out of the block (no rockers on the L heads) And they check out.
I'm going to replace the valve springs, they are the originals and there may be one or more that are floating... it would explain all symptoms. Just waiting on parts. If that doesn't work, I don't know.
TDI swap, lol
