New project coming up.
I'll be picking up 2 HPD30 housings from a local WF member. One from a 92, the other from a 97. The 97 has reinforced control arm brackets (gussets), new artec trackbar bracket, stock knuckles, and unit bearings, bad ball joints on the passenger side, bombshell diff cover, and missing the bracket for the steering dampner. Also a couple tie rod ends, and drag link.
The 92 is just that, an empty 92 housing.
Plan for this is to use the 97, maybe sell the 92. Ill media blast and repaint the housing and knuckles, maybe upgrade the gearing to 4.88 or 5.13 (maybe). The plan is to reuse my bearings, rotors, brakes, axle shafts and install mini skids. This will be somewhat of a slow build, and I may try to regear it myself.
