Can't wait to see the work this weekend - are you keeping the flares off for good or replacing them?It's a long process. Most of it discussing what is going to work and what is not. I might have gotten impatient at one point but they all slowed me down and we got the clearance that was needed after some minor adjustments. I am headed on a work trip today and taking the jeep to try and get everything broken in and settled.
It looks good! I'm glad you got it done. That is a ton of work you guys did!
I'll replace them with something soon. I don't want to go thru winter without. Though I haven't found a replacement yet.Can't wait to see the work this weekend - are you keeping the flares off for good or replacing them?
... I am trying to feel the valving change thru the movements as @jjvw mentioned and I am not sure if what I am feeling is exactly that. ...
So not as exciting as last weekend but I finally fixed my speedometer! It would jump all over the place. Cruising at 65 it would read 20, then it would jump to 100+. I tried the sensor wiring first because I thought it was a bad connection, no luck. Then I tried to remove the driveshaft to torque the output shaft nut only to be dealt a stripped bolt. So today I finally worked the bolt loose, torqued the nut, and speedo is solid again. I miss tracking mileage. It's been acting weird since maybe very late last year. I used the butt splice heat shrink connectors too just to clean up the old connection anyway View attachment 111995
Yes. Every thread I found pointed to the nut not being torqued tight enough. I want to say jb conversions requires that nut to be 220 ft/lbsDo you have the blue monkey speedo healer? Mine does the exact same thing if I hit a bump hard enough.... Might have to try this out.
Double adjustable would sure be nice
I’d be fiddling with them often enough I’m leaning that way myself. Hopefully you’ve got the vibes though after this round
